Alexa skill doesn't work. Tried everything
    #16
    Originally posted by spud View Post
    Could you do this:
    From Tools > Scripts commands, enter hs.debugmode=2048 then click run
    this will turn on json debugging
    then try the command that fails from Alexa, and post here what you get in the logs
    thanks
    I'll have to go through the upgrades to .17 again first. I'm not at home today but will hopefully be able to do this tomorrow.
      #17
      Hi,
      works perfectly in French with HS3. 😁😁
      Even if it is not officially supported.😊😊
      Jean-Francois
        #18
        Lately we've noticed that we're getting a lot of "sorry living room light is not responding" (or pick another device) particularly when we go to bed. My wife asked last night, "what's wrong with Alexa these days?" I told Alexa to discover then it works. This has happened the past two nights.
          #19
          I'm trying to investigate the Alexa issues that happen specifically with HS 4.1.17.0
          If you have some problems with Alexa with other versions please open new threads
          Jez,
          zakrzep
          can you tell me if you are using the HomeSeer Home Automation Skill (i.e tell HomeSeer) or the HomeSeer SmartHome Skill ?
            #20
            Could you do this:
            thanks
            This is what I get in the logs when running debug and issuing an Alexa command:
            6/23/2021 11:10:19 AM
            HomeSeer
            DEBUG JSON
            Query: request=echocontrol&command=ON&ref=258&token=117244771818771 77534
            Alexa response: "XXX isn't responding. Please check its network connections and power supply." XXX represents all HS devices that are shown in Alexa.
              #21
              HomeSeer
              DEBUG JSON
              Thanks that is helpful
              Can you tell me which skill you are using?
                #22
                When I upgraded to V. 4.1.17 that’s when my problem started before that no issues at all.
                  #23
                  Could you do this:
                  Also, please tell me which skill you are using
                  thanks
                    #24
                    Could you do this:
                    thanks
                    Hi Spud,
                    Sorry for the late response. I haven't been at home. Attached is a screenshot of the result that I got. Thanks. Click image for larger version
Name:	Alexa commands.png
                      #25
                      This error was using the Homeseer skill, not the Homeseer SmarHome skill. However, I haven't gotten the HomeSeer SmartHome skill working again either. It is currently disabled.
                        #26
                        I am using the homeseer smarthome skill.
                          #27
                          I upgraded to 4.1.17.0 on Linux. I am using the "Homeseer" skill. All of my devices can still be controlled by Alexa, and I did not refresh or reconfigure anything on the Alexa side. It simply works.
                          In related news, 4.1.17.0 fixes the long-standing bug with Google Home getting device status from HS. I didn't have to re-sync or otherwise mess with my Google Home/HS4 settings. Yay!
                            #28
                            Could you do this:
                            thanks
                            Jun-23 22:35:52 DEBUG JSON Query: request=echocontrol&command=ON&ref=414&token=437410865628173 08661
                            Spud I am using the homeseer skill
                            above is the single line that come up in the log
                            Could you tell me ow to turn this debug mode off some time please
                            let me know if you want anything else
                            Phill
                              #29
                              I am also using the homeseer smarthome skill. Stopped working after 4.1.17.0. And to clarify, I am on Windows. That might be the difference between some users working on Linux?
                                #30
                                Phill
                                thanks
                                To turn off json debugging, run the following script command
                                hs.debugmode=0
