Amazon Echo Latency
I have no latency issue at all. In fact, when I ask Alexa to turn off the bathroom light, the light turns off before she answers OK!
Steve Q
Sent from my iPad using TapatalkHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
I don't have any latency either. Earlier this year I did have some problems. As it turns out Echo is very dependent on upload speeds. Echo converts your voice to a wave file and uploads it to the Amazon servers. When my modem was acting up it slowed to a crawl and occasionally failed altogether due to my upload speed dropping below 1 mb/s. When that occurred HS commands were slow or failed and Echo's responses were slow as well.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rotunnoe View Post
My computer is running Windows 2008 R2. Its an Intel i3 3.3 GHz processor. It has 500 GBs of hard drive space and 24 GBs of RAM. CPU usage hangs around 50% usage whether the HSTouch Plugin enabled or not. I'm assuming that this is well within proper specs? The latency is occasional. I had assumed that since the connection between the Echo and HomeSeer aren't communicating directly on the LAN but rather interface with each other in the cloud somewhere that the occasional latency might be internet based. However with all of you saying that you don't experience latency at all, you're making me rethink myself.
