I created some routines so I can say "Alexa, open/close shade x" instead of "Alexa, turn on/off shade x". However, lately I am having troubles with this as Alexa either doesn't do anything, tell me that the device doesn't support this and some other error message. When I play the corresponding routines through the Alexa app it worked flawlessly during my testing. That makes me believe that in most cases Alexa let's HomeSeer execute my command "Alexa, open/close shade x" instead of executing the routine. That's probably because in HomeSeer I use the same name for the shade as I do in the routine. So then HomeSeer recognizes the device but doesn't know what "open"/"close" is.
Is there some way to either make Alexa execute the routine or have HomeSeer understand what "open"/"close" means? Btw, I don't want to give the device a different name in HomeSeer or Alexa because I also want to be able to say "Alexa, set shade x to y percent".
