HS Virtual dimmer switch controlled by Alexa Routines
    I Was using HS3 Alexa V2 skill, and I've couple of virtual level switches which I used to set with Alexa routines, and few events used to run based on what level was set. I updated the V2 skill to V3 (latest that is listed on the skill store), and not I'm not able to set the level of the switches, only can turn them on/off. Setting a level just turns them off. What has changed between the skill? Pls see the virtual switch below, I was not having the range 4-99 and 100 defined below, was having only 0 as off, 1, 2 & 3 as Dim. But since it was not working, I changed the switch to below, still the same thing.
