Which flow are you using ?
Mine or something else?
Which MQTT method in HomeSeer are you using ?
[EDIT]
OK, so, the alexa nodes in node-red does not read MQTT by default, so you can't just pass the MQTT data directly into one of them and expect it to work.
You have to parse/split the message up into a friendlier format which is what my flow does (1st post).
Copy it from that post and paste it into a new flow, add your account info and modify the MQTT listener and you should be good to go.
[EDIT]
