Alexa Skill Issue
    Alexa Skill Issue
    I Enabled the Homeseer Smarthome Skill on alexa. It all works fine and good. But I uninstalled 2 devices after installing them because they were in the wrong room on accident. Later figuring out there was a better way to changing the room. The issue now is I can't get the devices to show back up. I deleted the z wave device from my homeseer and reinstalled it and it still won't show up on Alexa. Anyone else have this issue or find a workaround or fix.
    I'd recommend putting in a support ticket on this issue here:
    https://dev.homeseer.com/servicedesk/customer/portal/2
    -Rupp
      Just to be sure
      1. clicked "forget" on the alexa smarthome devices
      2. clicked on "voice command enabled" in homeseer
      3. clicked "Discover" in the Alexa smarthome devices
      I have over 100 devices on my alexa smart home set up and I've had the same issue twice in the past. I ended up forgetting all the devices. Turning off "the voice enabled" from all the devices and then enabling 3 or 4 at a time until I found one device that for whatever reason was causing a problem. I added "voice command" text and tried again and it seemed to work. If you only have a few devices it might be worth a try.
      James
      Running HS 3 on Win10 .
        Originally posted by jasv View Post
        Just to be sure
        That was it. Problem child was garage door through myq plug-in. I have not been able to get it working with Alexa yet but that one garage door isnt that important.
          Cool. Thank you for the update.
          James
