As per title, running a routine/scene in Alexa to run an event in HS is often hit & miss… for example, you say “Alexa, turn on outside lights” which is connected to a specific event on HS… Alexa says “OK” - sometimes it works instantly, sometimes after some seconds or a minute… some others it doesn’t at all… if you ask again, it may work instantly…
I’m inclined to speculate it has to do with the connection to myHS being not as reliable / real time as would be desirable…
I can live with that… but was wondering if there’s any way to actually know when a scene/routine invocation has not gone through to HS… similar as to when you control a device directly and you get a “device not responding” feedback message from Alexa
any thoughts?
any thoughts?
