I've read through the existing threads and tried all of the "fixes" and NOTHING works. I simply cannot discover ANY Homeseer connected devices anymore.
A little background, I've been successfully using HomeSeer (Zee S2 Lite, currently on 4.2.16.0) with Alexa voice commands since Summer 2020. Even after going through the upgrade to HS4 a while ago so was still fine. I even recently added a GE branded Jasco dimmer in late November 2022 and that was discovered without issue. Well as of the last couple of days, after adding an Enbrighten branded Jasco dimmer (new gen), Alexa will not discover the switch...or anything else connected to HomeSeer.
What's strange is all of my existing devices DID still work through voice control. Then of course I followed the "magic fix" of disabling voice control through bulk edit, unlinking the HS Smart Home skill, and DELETING ALL DEVICES from Alexa, rebooting the HS device...and now I'm dead in the water as nothing will re-discover. Not even the devices that were working fine prior to all of this.
I have/had about 25-ish voice enabled devices (mostly smart switches, a few smart plugs and a couple of smart thermostats --- no events were voice enabled.) I can't even discover a single voice enabled HomeSeer device n Alexa (all others are disabled from voice control). I even tried deleting the new Enbrighten smart switch from the mix.
