The smarthome app shows all my devices off line. Asked Alexa to discover them and reply no devices. I disabled the app and enabled it again. It asked for my HS user name & PW...Entered it and this is part of the message that came up
Server Error in/Application
database master on server myhs-sql is not corrently available
Line 18:
Line 19: For Each enumValue As eUserLevel In enumValues
Line 20: Role = RoleManager.FindByName(enumValue.ToString)
Line 21: If Role Is Nothing Then IResult = RoleManager.Create(New IdentityRole(enumValue.ToString))
Line 22: Next
SqlException (0x80131904): Database 'master' on server 'myhs-sql' is not currently available. Please retry the connection later. If the problem persists, contact customer support, and provide them the session tracing ID of '{31508C10-5C8D-423B-8DE6-9852DFF40FB8}'.]
System.Data.SqlClient.SqlInternalConnection.OnError(SqlExcep tion exception, Boolean breakConnection, Action`1 wrapCloseInAction) +110
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(Tds ParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +345
System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4927
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +81
System.Data.SqlClient.SqlInternalConnectionTds.CompleteLogin (Boolean enlistOK) +54
System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLog in(ServerInfo serverInfo, String newPassword, SecureString newSecurePassword, Boolean ignoreSniOpenTimeout, TimeoutTimer timeout, Boolean withFailover) +451
System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailov er(ServerInfo serverInfo, String
any info on this problem?........................
I was just able to enable the app. It seems fine now. Was there an update to the system?
Line 18:
Line 22: Next
