I have a few z-wave plug-in scokets to turn on or off some lights, they can not be dimmed. They appear as a switch in the home app, so I cant say turn off lights... How can i fix this ?
Non dimmable light not seen as light (seen as switch)
Originally posted by kriz83 View PostI have a few z-wave plug-in scokets to turn on or off some lights, they can not be dimmed. They appear as a switch in the home app, so I cant say turn off lights... How can i fix this ?
Sent from my iPad using TapatalkHS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
I'm having the opposite problem. All of my Z-Wave devices (except the door locks) are reporting to Google as lights. The "Is Light" checkbox is clear for those devices that aren't lights. Specifically, I have a ceiling fan (using a HomeSeer fan controller) and a bathroom fan (using a HS-WS200+) reporting as lights.
Wonder what happens if you set it as dimmable. Shouldn't hurt anything. Just may not turn on.
Edit: come to think of it, HS gets info about the device from the device data stored in the device by the manufacturer. They tend to call these things a switch. Dimmable ones are multilevel, non dimmable are binary.Regards,
Michael
HS3, W10 Home, HSTouch, W800, Z-Stick+
Originally posted by stvjfp1 View PostSet it as dimmable has now effect, but going to Status Graphics flip, and changing the controll use to dim, and then syncing it to google home, and it will show up as a light.
Homeseer should fix this ASAP.
I have the same issue. I use GE z-wave switches. Dimmable ones show up as lights while Toggle on/off switches show up in google as switches. Even though is light is checked in Homeseer. My fan controls also appear as lights. Which poses a problem when I tell google home to turn on the lights in the living room it also turns on the fans. So after that I have to say “Turn off the family room fans”. The “is light” box is cleared for fans.
I also have several Aeon labs smart switch 6 plugs that I cannot get google home to recognize. The Root device will sync with google home, its seen as a light but when you control it from google home it does not work, because its trying to control the root device and not the child switch binary on/off device.
I have 1 aeon labs nano switch gen5 that works as intended. I enable voice control on the Z-Wave Switch Binary child device and google home sees it as a switch and is able to control it. It sees it as a switch like it should.
