I have one Google Account and two HS4 installations on two different machines in two different houses in two different states. I got into HS4 after we were all abandoned by Insteon.
I now have two HS4 installations each with the Insteon Plugin. Both the HS4 installations are on the same MyHS account. I linked that account to Google Home yet only the devices for one of the HS4 installations appears in Google Home. I'd like the devices of both HS4 installations to appear in Google Home. How do you do that?
Now this next part is a little tricky. I've been doing experimentation with both the Insteon Plugin groups, HS4 Events and Google Home routines none of which gets me what I'm looking for like the Insteon cloud did. Back in the Insteon day if you created a "scene" it appeared as a device in Google Home. If you had more than one hub in separate locations all devices and scenes were seen by Google Home.
If you create Insteon Groups they do appear in the HS4 device list but they all simply say "Group Controller". So you don't know which is which. Not very useful in the HS4 apps but they do appear in Google Home as devices with the proper name but for only one installation.
If you create events in HS4 you can easily use them in HS4 and they can be used as dashboard widgets in the HomeSeer app. However, Google does not see them at all.
If you create a Google Home Routine you can only do so for one HS4 installation per account (as far as I can see). Those routines are not available in HS4 (for obvious reasons).
What I'm looking to do is to create something that can control multiple devices that can be seen and used in the HomeSeer app, HS4 web page and Google Home without creating multiple occurrences of the same group, event, routine so that each interface and see and interact with it.
Has anyone accomplished that?
