If this is your first visit, be sure to check out the FAQ. You must register before you can post. Your first post will be checked for appropriate content
(SPAM) - please allow a bit of time for that. After that, you'll be able to post at will!
I'm new, what does this allow you to do exactly? I don't really know what IFTTT does.
IFTTT is a cloud based rules engine that allows you to integrate many disparate systems. From a HS3 perspective, it's a way to integrate systems with HS3 that don't have a plugin. Since it's cloud based, the integration breaks when your internet connection is down, but it still has its uses. Here's a full list of all the things that are currently supported by it: https://ifttt.com/search/services. The rules engine is pretty limited as it only allows triggers without any conditions.
Coincidentally I was just trying this with my kwikset lock. I couldn't find it.
I remember reading somewhere to change the 'control use' option under the advanced tab of the device to anything other than 'not specified'. I did that and it works now. Try it and see.
