It is happening randomly and by reading all these posts, the issue remaining with the connections to different servers. IN PHLocation, I created 3 profiles, one with connect2, the other with ca and the other with 33. It works randomly. On Friday it was working fine with connectca but not with the default 2, today works only with connect2. Is there any permanent solution?
Curiosity, if I directly connect to a server, as an example connect2, why it should not work and redirect? I understand if you are using myhs.homeseer but connnect2 should be a direct request to that server.
