I have two HS4 systems one in the house and the second in my garage, first one is a full windows Pro version wired to my main network with a fix Ip adress 192.168.2.170, I have a second router serving it's own clients wich is connected to the first network in my garage, my second HS4 system is running on a Pi connected to that second router (192.168.8.170)
Both systems have separates users created on myhs
My problem is locally i can connect via myhs to my house HS4 Windows Pro but can't connect to the garage HS4 Pi. Once i enter the login for the second system on the myhs page, after about 1 minute i have a message returning 'this site is unavailable' and it shows the HS4 Pi IP adress; 192.168.8.170
If i try connecting via WAN everything is working fine
Would anyone would have a hint on my problem ?
