Registered new system with with MYHS today using license ID and license password. Tried to access a device directly on my HomeTroller plus system and access was denied. Tried to log in on another computer with web interface and access is also denied to all device settings.
Immediately after registering with MYHS - Access is denied - solved!
Originally posted by Al NN4ZZ View PostWhat was the fix? Similar issue here. Was working with admin access until I registered with MYHS, then access denied error pop up when trying to do many of the options.
Thanks...al
From here, delete the users.cfg file. If you have file extensions hidden, this will appear as just "users".
Next, restart HS4. You will now be able to log in with the username and password "default".
Navigate to Setup, then the Users tab and add an account with your MyHS credentials and give it Admin and Local access, and you should be all set!
How do I locate this folder:
From above: navigate to the HomeSeer HS4 program folder and open the Config folder, the default file path is C:\Program Files (x86)\HomeSeer HS4\Config.
I don't see the "HomeSeer HS4" folder in my PC C: drive ( C:\Program Files (x86) directory. The "HomeSeer HS4" folder does not exist. In the HELP DESK report is says my configuration file is "In Virtual Machine." See copy below.
How do I access this virtual machine?
I'm using a HomeTroller hub. Are the instructions above for the hub access installation?
Also when I'm able to find and delete the users file and log back in are you saying the USERNAME is "default" and the PASSWORD is also "default"
HELP DESK
Date/time
4/27/2022 7:38:11 PM Eastern Daylight Time
Version
HS4 Standard Edition 4.2.7.0 (Windows)
License
Registered
License ID
6XXXXXXXX (I XXed out the actual ID number...al )
MyHS Subscription
Basic
MyHS Subscription Backup Interval
No Backup
MyHS Subscription Max Cameras
Confguration File
C:\Program Files (x86)\HomeSeer HS4\Data\HomeSeerData.json
In Virtual Machine
...Al
HELP DESK
Date/time
Version
License
Registered
License ID
MyHS Subscription
Basic
No Backup
Confguration File
In Virtual Machine
...AlHS4Pro on a Raspberry Pi4
54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
HSTouch Clients: 1 Android
Originally posted by Al NN4ZZ View PostHow do you see/look for files on the hub? When I access the hub from it's IP address, the application to control it comes up. I don't see any files, etc.
Having a similar problem in HS3 after moving to a new PC (hard drive failure). Getting invalid username or password when attempting to access MyHS. Have tried resetting password multiple times. Name and password agrees with info in Setup. Have tried the Rupp instructions to no avail. Suggestions?
Current Date/Time: 6/22/2022 5:46:48 PM
Operating System: Microsoft Windows 7 Home Premium - Work Station
System Uptime: 0 Days 0 Hours 38 Minutes 1 Second
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Event Threads: 0
Email Send Queue: 0
