I have copied and pasted it into the change node. It wasnt working, I changed the dim level a few times, then I attached a debug node to the output of the change node, and nothing is coming through at all
Keeping a Node-Red Dashboard in sync with HomeSeer
This is a sticky topic.
Sorry, I messed up the JSONata expression. It should be:
Code:$number($replace(status.text, /[^0-9]/, ""))
I would recommend the changes suggested below as well. You do not need a copy of the same Change node for each dimmer.
Karl S
HS4Pro on Windows 10
1070 Devices
56 Z-Wave Nodes
104 Events
