I have node red installed via npm on windows 10. I use task scheduler to start it after an automatic windows login. I'm currently using HS 4.1.4.0 on the same Win 10 machine.
I have one flow that monitors an HS device to post TTS to alexa. The HS device shows yellow with a full list of HS devices and the alexa end shows green/ready. But no action occurs when the monitored HS device changes.
HS shows a log error "Posting to webhook failed: Unable to connect to the remote server"
To resolve this I can try restarting the flow which worked once. Twice I've had to go to task scheduler and end the task, then rerun it. Last failure before today was 5 days ago.
This item is not mission critical but surprisingly it has relatively high WAF
Any suggestions or thoughts?
