Hi,
I have been googling around trying to work this out but as I am not much of a programmer i am not really getting anywhere..
What i wanted to do was simply link Home Assistant sensors to devices in Homeseer, however i am struggling to work out how to create the extra .status or .payload into the message for msg.payload.value or msg.payload.status with an aim of adding the original payload.
I have edited the topic using the change node before sending on to the HS Device Node which is fine
I can successfully change the HS Device with the inject node as i can create the correct msg format as per the screens in the flow examples so everything is fine at the backend
I have got it going Homeseer to Home Assistant but its this extra bit with adding .value or .status to the msg which is causing me headaches
I am probably missing something basic or not searching for the right thing so apologies in advance
Thanks for any pointers
