Node-red gives double update bug.
    #16
    Originally posted by ksum View Post
    There is also the Throttle contrib which can limit passing messages to once every X seconds. So setting it to 10 seconds means it only passes a message once every 10 seconds.
    Hi ksum,
    yeah i did try that one but doesnt work at all.
    i used By Count but when select 2 counts it still trigger the wrong one.
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
      #17
      Looking back at your debug items: If the device's Value and Status will always ultimately be the same, and you do not want to proceed until they are, add a Switch node which has one condition. status=value. It appears the switch comparison will compare a string to number:
      This put this in after teh HomeSeer item and you will only go past it when the two are equal. If they may have different values, then we need to find something else to filter on.
      Karl S
      HS4Pro on Windows 10
      1070 Devices
      56 Z-Wave Nodes
      104 Events
        #18
        Did you guys try the "contains" condition in the switch node?
        Eman.
          #19
          Click image for larger version  Name:	hs3.png Views:	0 Size:	15.9 KB ID:	1428820
          I did try that and it does not trigger,
          i think thats because that there is a very small chance that value gets a delay aswell so it can't compare to status.
          Well i did try throttle and got it to work and works very good.
            #20
            Also i did find out another issue related by the double data,
            in node-red itself (webbrowser) when i debug a device by a plugin, for example my power produce it sends the message 1x, thats allright.
            when i check in the node-red command window i see this (double data)
            while in my web browser using debug it sends only 1x..
            i dont know if this is normal, but i checked influxdb and the data is 1x thats good
            ref: 6000,
            name: 'Electricity produced (current)',
            location2: 'Plugwise Smile',
            value: 1522,
            status: '1522 Watts',
            last_change: '/Date(1603787318330+0100)/'
            device update:
            ref: 6000,
            value: 1522,
            device update:
              #21
              Maybe the Command Window is showing the the data sent down each wire? If I understand you correctly this is when you have a debug connected to a node and also another item connected to that node. I am not sure what you mean by the Command Window, though, so I cannot see if I get the same behavior.
              Karl S
              1070 Devices
              56 Z-Wave Nodes
              104 Events
                #22
                ow sorry i mean windows command window.
                  #23
                  Okay. I am running on a Raspberry Pi. I believe you are seeing the logging, which would show multiple wires. Try connecting another debug node, or better, a switch or other node which can be a dead end so you have 3 wires coming out and see if you now have it report 3 times. If it does, you are seeing a log of each wire. Which would make sense. I posted in the Node Red Slack to ask if this is true but have not yet received a reply. If/when I do I will update here.
                  Karl S
                  1070 Devices
                  56 Z-Wave Nodes
                  104 Events
                    #24
                    i did check but nothing connected,
                    look my screenshot Click image for larger version
                      #25
                      2 of the above ref : have similar details .....?? What are you looking for in those details?
                      Eman.
                        #26
                        Eman.
                        If u look at ref:5998 its exactly the same.
                        they are double, thats what i'm looking at
                        so its still double reporting somehow, i just want to know if thats normal or not.
                          #27
                          Have you tried connecting a second debug node and see if you get 3 of the same? I am thinking that is standard for debug messages but I have no response in the Node Red slack. Since you are not seeing any additional messages in the browser nor influxdb then you should be good.
                          Karl S
                          1070 Devices
                          56 Z-Wave Nodes
                          104 Events
                            #28
                            Malosa Is that duplicate message coming out of a Switch node which has multiple conditions and all conditions are being tested? Wondering if it is passing two tests and reporting such.
                            Karl S
                            1070 Devices
                            56 Z-Wave Nodes
                            104 Events
                              #29
                              How do your HomeSeer nodes look inside (properties)? Do you have the check box enabled?
                              Because if checked the node reports back to Node-RED (let's hope it's not that)
                              Eman.
                                #30
                                ksum well if that was true all other devices would report double aswell, all the nodes are the same, i used one to change the payload name on all of them.
                                Well i must say on influxdb its not double, so it could be a normal debug thing.. idk
                                my last couple of value's in influx db, all good
                                1603953171906000000 0.771
                                1603953413598000000 0.827
                                1603953720205000000 0.883
                                1603954024897000000 0.935
                                1603956468355000000 0.958
                                1603956711694000000 0.963
                                1603957932516000000 0.976
                                1603958241583000000 1.026
                                1603958544257000000 1.083
                                1603958851835000000 1.089
                                1603961231830000000 1.206
                                Eman.
                                Eman
                                No check enabled.
