Node-red gives double update bug.
    #31
    So remove the debug node, Malosa and see if one of the messages goes away. You could just delete the wire to test this is you feel you need to keep the node long term.
    Karl S
    HS4Pro on Windows 10
    1070 Devices
    56 Z-Wave Nodes
    104 Events
      #32
      Originally posted by Malosa View Post
      Well since i checked my influxdb i did see double value's all the time after a status and value gets updated by 1 device.
      This to me points to the device being updated twice by the plugin or script that is updating it and has nothing to do with node-red as you say it is fine for other devices. What is shown in the HS log when the device is triggered. Is it displayed twice in there?
      So when it updates and i check the output in node-red it triggers 2x, 1 time for status and one time for value in a second..
      How do you know the update is for the value one time and the status another as both values in the debug are the same?
      Scripts =
      Various
        #33
        no its not updated twice, i just did debug on the homeseer plugin and its updating 1x the same value.
        no wire for debug is connected.
        well its not a big deal but can this cause instability issues?
        its happening to some of the devices i did not check them all because i enabled over 20 devcices..
        Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
        HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
          #34
          Node-RED and HomeSeer versions....?? Although I don't think that could be a problem ..??
          The whole screenshot of your setup..??
          Eman.
            #35
            Click image for larger version  Name:	image_94938.png Views:	3 Size:	297.2 KB ID:	1429668
            Eman.
            HS4.1.5 and the last node-red.
            this is the plugin i getting info from.
              #36
              There is that Change Node "Gas Daily Total" at the bottom, although not connected to anything but I think would it would give you similar values as the one above it "Gas consumed total today" If you don't need it delete it.
              And something else, split the nodes into 2 function nodes going to HomeseerENERGY and test by first removing half of the nodes
              Eman.
                #37
                Gas live day total gives me only 1 x value with the throttle node, that was the one giving double status on influxdb i solved that with the throttle node instead of RBE.
                While the rest almost all give 2x value in th windows debug screen and not node-red and in influx db.
                1.Some devices are reporting double payload because of the delay of value-string in Node-Red
                2.Some devices not reporting double payload in Node-Red but in the windows console window, while not connected to any debug line.
                I'm very sure homeseer need to fix the webhook,and delay it with 1 ms, i see when a value and status change its faster updated in node-red than homeseer self.
                i don;t think it causes stability issue's.
                here my list of some double items, u see some devices update double because 1 value did delay while update,
                but some of them not.
                The temperature sensors are MQTT
                some of them in the list below are virtual devices and plugin of plugwise.
                this is the list of only the power management and temperature from past 10 seconds
                regards
                 ref: 5689,
                location2: 'Temperature',
                value: 17,
                status: '17°C',
                last_change: '/Date(1604041893743+0100)/'
                device update:
                ref: 5904,
                location2: 'Plugwise Device',
                value: 0,
                status: '0 Watts',
                last_change: '/Date(1604041896793+0100)/'
                device update:
                ref: 5998,
                name: 'Electricity consumed (current)',
                location2: 'Plugwise Smile',
                value: 409,
                status: '409 Watts',
                last_change: '/Date(1604041899421+0100)/'
                device update:
                ref: 5998,
                value: 409,
                device update:
                ref: 5904,
                value: 0.266559463246038,
                status: '0 Watts',
                last_change: '/Date(1604041900842+0100)/'
                device update:
                ref: 5998,
                value: 398,
                status: '398 Watts',
                last_change: '/Date(1604041905185+0100)/'
                device update:
                ref: 5998,
                value: 398,
                device update:
                ref: 5904,
                value: 0,
                status: '0 Watts',
                last_change: '/Date(1604041908920+0100)/'
                device update:
                ref: 5992,
                name: 'Peak electricity consumed (total)',
                value: 1670.436,
                status: '1670.436 kW Hours',
                last_change: '/Date(1604041916613+0100)/'
                device update:
                ref: 5992,
                value: 1670.436,
                device update:
                ref: 5998,
                value: 402,
                status: '402 Watts',
                last_change: '/Date(1604041916670+0100)/'
                device update:
                ref: 5998,
                value: 402,
                device update:
                ref: 6001,
                name: 'Gas consumed (total)',
                value: 2052,
                status: '2052 m3',
                last_change: '/Date(1604041916709+0100)/'
                device update:
                ref: 6001,
                value: 2052,
                status: '2052 m3',
                runEvent id=142
                device update:
                ref: 3972,
                name: 'Live Gas Hour',
                location2: 'Gas Check',
                value: 0.04,
                status: '0.032',
                last_change: '/Date(1604041916741+0100)/'
                device update:
                ref: 3972,
                value: 0.04,
                status: '0.04',
                last_change: '/Date(1604041916751+0100)/'
                device update:
                ref: 3973,
                name: 'Live Gas Consumed Hour',
                value: 0.752,
                status: '0.712',
                last_change: '/Date(1604041916769+0100)/'
                device update:
                ref: 3973,
                value: 0.752,
                status: '0.712',
                device update:
                ref: 3973,
                value: 0.752,
                status: '0.752',
                last_change: '/Date(1604041916771+0100)/'
                device update:
                ref: 3973,
                value: 0.752,
                status: '0.752',
                device update:
                ref: 3974,
                name: 'Live Gas Cost',
                value: 0.49,
                status: '0.46 €',
                last_change: '/Date(1604041916799+0100)/'
                device update:
                ref: 3974,
                value: 0.49,
                status: '0.49 €',
                last_change: '/Date(1604041916801+0100)/'
                device update:
                ref: 5904,
                status: '0 Watts',
                last_change: '/Date(1604041917032+0100)/'
                device update:
                ref: 5904,
                value: 0,
                status: '0 Watts',
                last_change: '/Date(1604041925132+0100)/'
                device update:
                ref: 5904,
                status: '0 Watts',
                last_change: '/Date(1604041933403+0100)/'
                device update:
                ref: 5904,
                value: 0,
                status: '0 Watts',
                last_change: '/Date(1604041941559+0100)/'
                device update:
                ref: 5904,
                status: '0 Watts',
                last_change: '/Date(1604041945611+0100)/'
                device update:
                ref: 5904,
                value: 0,
                status: '0 Watts',
                last_change: '/Date(1604041953717+0100)/'
                device update:
                ref: 5816,
                location2: 'Humidity',
                value: 52,
                status: '52%',
                last_change: '/Date(1604041955859+0100)/'
                device update:
                ref: 5811,
                value: 19,
                status: '19°C',
                last_change: '/Date(1604041955880+0100)/'
                device update:
                ref: 5816,
                value: 53,
                status: '53%',
                last_change: '/Date(1604041958352+0100)/'
                device update:
                ref: 5811,
                value: 20,
                status: '20°C',
                last_change: '/Date(1604041958369+0100)/'
                device update:
                ref: 5904,
                status: '0 Watts',
                last_change: '/Date(1604041961817+0100)/'
                  #38
                  Now I know. There should not be any problems because the HomeSeer nodes also report status!
                  Try to add a few of them extra and check...?
                  It would sound weird but it's like they receive the data from the script and they acknowledge then they pass it on.
                  You are the first one I saw who has got your HS device nodes before the Change nodes (because you are collecting data to feed into grafana)
                  Eman
                    #39
                    Eman
                    maybe thats the case nobody reported that issue i have.
                    yeah i wanted full status on grafana so i can track everything.
                    I have atleast 40 devices doing that every second. but like you seen some of them report double but not in grafana.
                    for now i solved the double data in influx/grafana with that node mentioned by ksum, and it works good for me.
                    that other double data i don't care its only logging, but i will care if its get instable when i gonna add all my other devices, but we will see.
                    i'm very happy with the integration of node-red in homeseer, it solve a lot of problems so i can finally track everything
                      #40
                      Malosa Sorry for jumping into this late but I think I can see the root of the problem you are having. It's in your script calls.
                      Instead of this:
                      Dim Ref
                      Ref = hs.GetDeviceRef("PWR-YDAY-GAS")
                      hs.SetDeviceValueByRef(Ref, data, True)
                      hs.SetDeviceString(Ref, data, True)
                      Try this:
                      Dim Ref
                      hs.SetDeviceString(Ref, data, False)
                      What your script is currently doing is triggering a "last change' twice by having the third parameter of both calls set to "True".
                      EDIT: I found something else interesting. The webhook will only report a change IF the string or value changes, even with "last change" set to "True". However, correctly, it will not report a change when "last change" is set to "False", even if the string or value changes.
                      Hope this helps,
                      Ken
                        #41
                        Instead of this:
                        Dim Ref
                        Try this:
                        Dim Ref
                        Hope this helps,
                        Ken
                        sorry for the late reply,
                        well i must say u right about the script issue, indeed setting one of them to false solve the issue,
                        but the one with some plugins remain, i will ask dev to change the double change.
                        many thanks for that.
                          #42
                          kenm
                          well here is an update,
                          it still doesnt work.
                          only work sometimes sadly.
                          regards
                          1/26/2020, 10:02:28 AM[URL="http://192.168.1.12:1880/#"]node: testoutput[/URL]msg.payload : Object
                          objectref: 6423
                          name: "Live bruto power produce"
                          location2: "GROWATT"
                          value: 168.5
                          status: "168.5 "
                          last_change: "/Date(1606381363681+0100)/"
                          11/26/2020, 10:06:55 AM[URL="http://192.168.1.12:1880/#"]node: 93238ca6.d6496[/URL]msg : string[24]
                          "Creating handler for all"
                          11/26/2020, 10:07:28 AM[URL="http://192.168.1.12:1880/#"]node: testoutput[/URL]
                          object
                          ref: 6423
                          value: 212
                          status: "168.5 "
                          last_change: "/Date(1606381663640+0100)/"
                            #43
                            I know this is an older thread, but was it ever fixed?
                            I have the same issue with a virtual object in HS4 sending web hooks to node-red. I get duplicate web hook messages for a property change. The messages are otherwise identical, except the ref id is different, so it looks like duplicate messages are being created.
                            When I look in HS4 log, I see no dupes
                            I fixed it with the "filter" node in node-red, but that is more of a hack than a solution.
                            Erik
