Why is this msg.payload.status truncated ?
    I am trying to set a virtual vdevice feature with the following string:
    "https://dev.virtualearth.net/REST/v1/Imagery/Map/road/46.71111,-73.112121/15?mapSize=400,400&pushpin=46.71111,-73.112121&mapLayer=basemap&format=jpeg&key=private_key"
    Part of the string makes it in the status of the device but everything after the '&' (before pushpin) is rejected, is there any way to have HS4 accept the complete string ?
    You might have to escape it with a single \ right before the &
    HS4Pro on a Raspberry Pi4
    54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
    Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
    HSTouch Clients: 1 Android
      rmasonjr i already tried this solution but it keeps being rejected and don’t make it to the virtual device. Everything before makes it but as soon it sees the & it troncates the message even with ‘\’ before
        Maybe try &
          I’m away from my server, I’ll try this later this afternoon, thanks
            Can you post an image of how you are setting msg.payload.status, please? I copied your string, without the quotes, and am able to get the full string added using teh settings as shown below:
            Here is the debug out of the node from above:
            Karl S
            HS4Pro on Windows 10
            1070 Devices
            56 Z-Wave Nodes
            104 Events
              ksum here is how I manually inject my message that does not make it complete in the HS4 devise status:
              Click image for larger version  Name:	node-red.PNG Views:	0 Size:	27.1 KB ID:	1434053
              here is the debug
              Click image for larger version  Name:	node-red2.PNG Views:	0 Size:	39.8 KB ID:	1434055
              and here is the status ih HS4
              Click image for larger version  Name:	node-red3.PNG Views:	0 Size:	46.3 KB ID:	1434056
              And here is what I want to replace the manual injection with:
              using a change node:
              Set msg.payload.status
              (jsonata) "https://dev.virtualearth.net/REST/v1/Imagery/Map/road/" & msg.payload.iPhone[0].locationInfo.latitude & "," & msg.payload.iPhone[0].locationInfo.longitude & "/15?mapSize=400,400&pushpin=" & msg.payload.iPhone[0].locationInfo.latitude & "," & msg.payload.iPhone[0].locationInfo.longitude & "&mapLayer=basemap&format=jpeg&key=private_key"
                Originally posted by drhtmal View Post
                Maybe try &
                that does not work, it still stop at the &
                  in fact, any string containing '&' does not make it to the status of the virtual device at least in my windows environment
                    Can you set the status of the device to contain the '&' in HomeSeer or via a script? Maybe it isn't possible if holding such? What are the device's settings in HomeSeer?
                    Karl S
                    1070 Devices
                    56 Z-Wave Nodes
                    104 Events
                      Yes i am able to set the status via hs.devicestring in a string
                      in Fact, just received a note from spud for a question I asked in the node-red Homeseer integration in the github ‘issue’ section, this as been logged as a bug.
                      thanks all for the help
                        This is fixed in node-red-contrib-homeseer version 1.0.5 which has just been released
                          Thank you, spud The update will require you to restart Node Red. Here is a short flow to do that. Import it and then, after updating the Homeseer contrib, click the Inject node to restart Node Red. refresh your browser and all should be good.
                          [{"id":"8497fd50.d66e1","type":"exec","z":"4487e413.bb781c","command":"sudo ","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"System Command","x":720,"y":370,"wires":[[],[],[]]},{"id":"c8687228.7cd88","type":"inject","z":"4487e413.bb781c","name":"Restart node-RED","topic":"","payload":"node-red-restart","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":480,"y":370,"wires":[["8497fd50.d66e1"]]}]
                          Karl S
                          1070 Devices
                          56 Z-Wave Nodes
                          104 Events
                            thanks again to all
                            spud that was a rapid fix, special thanks
