Good morning all As Homeseer does not WANT to put other languages in the ALEXA skill than US English and I want to use my HS4 license, I need to find a solution. I saw this node:
https://flows.nodered.org/node/node-...ual-smart-home
which with the HS4 node should do the trick.
Lots of setup and hours to spend in front of the screen ....
While it's so easy with the Homeseer Skill !!!
As I said before, I was able to install the skill BEFORE Amazon regionnalises the Skill stores
I had installed the skill from the UK store and it works VERY well in French, including events.
Too bad for Homeseer there is only the US, the rest of the world does not exist ...
Happy end of year celebrations to all and may 2021 be better ...
JF
JF
