Trying to get Device Updates:
Receiving Device updates
Every time the device value or status changes in HomeSeer the node will send a message containing the new state of the device in msg.payload the new value of the device msg.payload.status the new status text of the device
I have checked within HS4 and the webhook is defined correctly. Node Red and HS4 are on the same RPI4 no firewall. Webhook URL is:
http://127.0.0.1:1880/homeseer/webhook Have also tried using the ip address or http://10.1.2.9:1880/homeseer/webhook
When I open a browser and connect to that url or its ip address instead of the 127.0.0.1 it prompts me with a userid/password box as Node Red is attempting to authenticate. I am using Node Red v1.2.9 which does require authentication. If I enter the correct credentials, Node Red service responds with "Cannot get /homeseer/webhook".
HS4 is currently set to not require authentication
Has anyone used to latest Node Red 1.2.9 or later to interact with HomeSeer?
Thank you.
Thank you.
