How to retrieve a value after a Node containing a status
    How do I get the value of a Node after a Node with a status.
    "Dag+1 windkracht" should be a value.
    [{"id":"323a88b6.821288","type":"change","z":"126a1381.26f28c ","name":"Dag+1 maximumtemperatuur (Max)","rules":[{"t":"set","p":"topic","pt":"msg","to":"update","tot":"str"} ,{"t":"set","p":"oldpayload","pt":"msg","to":"payload","tot" :"msg"},{"t":"set","p":"payload.value","pt":"msg","to":"payl oad.buienradar.verwachtingMeerdaags["0"].maxtempmax","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x" :520,"y":1600,"wires":[["828dd5d9.381068","daec88c7.ac3bd8"]]},{"id":"828dd5d9.381068","type":"change","z":"126a1381.26f2 8c","name":"Dag+1 windrichting","rules":[{"t":"set","p":"topic","pt":"msg","to":"update","tot":"str"} ,{"t":"set","p":"oldpayload","pt":"msg","to":"payload","tot" :"msg"},{"t":"set","p":"payload.status","pt":"msg","to":"pay load.buienradar.verwachtingMeerdaags["0"].windrichting","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x" :470,"y":1660,"wires":[["c95eb6bf.103158","9a0336d2.d19288"]]},{"id":"c95eb6bf.103158","type":"change","z":"126a1381.26f2 8c","name":"Dag+1 windrkracht","rules":[{"t":"set","p":"topic","pt":"msg","to":"update","tot":"str"} ,{"t":"set","p":"oldpayload","pt":"msg","to":"payload","tot" :"msg"},{"t":"set","p":"payload.value","pt":"msg","to":"payl oad.buienradar.verwachtingMeerdaags["0"].windkracht","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x" :470,"y":1720,"wires":[["288c7b69.8ca714","2ee191ed.52f18e"]]},{"id":"daec88c7.ac3bd8","type":"hs-device","z":"126a1381.26f28c","name":"Buienradar Dag+1 Day+1 Minimumtemperatuur (Max)","device":"4285","server":"649b964f.328f48","feature": "4292","reportonstartup":false,"x":900,"y":1600,"wires":[[]]},{"id":"9a0336d2.d19288","type":"hs-device","z":"126a1381.26f28c","name":"Buienradar Dag+1 Day+1 Windrichting","device":"4285","server":"649b964f.328f48","fe ature":"4295","reportonstartup":false,"x":850,"y":1660,"wire s":[[]]},{"id":"2ee191ed.52f18e","type":"hs-device","z":"126a1381.26f28c","name":"Buienradar Dag+1 Day+1 Windkracht","device":"4285","server":"649b964f.328f48","feat ure":"4296","reportonstartup":false,"x":850,"y":1720,"wires" :[[]]},{"id":"649b964f.328f48","type":"hs-server","name":"TEAPHomeSeerServer01","host":"192.168.1.99", "port":"80"}]
    John
    Do you want the status of the blue nodes while in the yellow node? Something needs to be placed before the yellow node to do this. What is your trigger to do what you are trying to accomplish as this could change what is used?
    Karl S
    HS4Pro on Windows 10
    1070 Devices
    56 Z-Wave Nodes
    104 Events
      I want the status of the yellow Nodes in the Blue (HS) Nodes. If th consecutive Nodes contains values it is going well. However in case there is a Yellow nod from which I want to capture the status (as it is text) the next HS Node will show the status instead of the value.
      To be clear the issue is not to get the info in the HS Node. the issue is to get the value into a Node after the previous Node is a status Node. Of Course I can connect the Nodes in another way to mitigate the issue, but I like to connect the yellow Nodes for clarity.
      For the Nodes containing a value I use
      For the Nodes containing text I use
      John
        I would remove the first to "Set" items from the bottom two change nodes. You already make those settings in the top one and you are then setting msg.oldpayload to what you are passing out of the previous change nodes. Otherwise this should be setting the HomeSeer devices to what you are setting msg.payload.status to in each change node. Connect a debug node showing the complete message to each Change node and make sure each is doing what you expect.
        Karl S
        1070 Devices
        56 Z-Wave Nodes
        104 Events
