So I broke my fundamental rule of never upgrade multiple things unless you have to for interoperability.
Last week MS installed an update on my WIndows 10 Pro machine that hosts HS4, after the reboot I was greeted with a HS4 update available so I installed HS4 Pro 4.1.15.
While I was at it I thought I'd check Node Red install for updates as its been a while. Updated NR to 1.3.2 and the node-red-contrib-homeseer to 1.06.
Everything is working as it was before, until I checked the log and I get
From the HS4 windows machine I can access Node Red and everything still seems to be updating. I have control of devices and status works, just lots of these messages in the log that I can't seem to associate with what is trying to be posted and why I get 4 of these messages in a row, with no device updates received that should trigger a update to NR.
Anyone have a clue where I can look?
HomeSeer 3 Posting to webhook failed: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server. URL: http://192.168.1.6:1880/homeseer/webhook
