Enable Node-Red as a service on Hometroller SEL / Ubuntu 14.04
    The scripts for setting node-red as a service in the manuals for installation of node-red uses "systemctl" for this purpuse. This is not supported in the 14.04 running on the Hometroller SEL.
    Using terminal-server, I can start node-red, but it stops when terminal server disconnects.
    I would like to have it enabled as a service, or start during reboot.
    How to?
    Install Node-RED on a Raspberry PI : https://nodered.org/docs/getting-started/raspberrypi Even better in ioBroker : https://github.com/buanet/ioBroker.raspberry-os on that Raspberry PI which will; give you a multitude of plug-ins including Node-RED (I suggest you leave the Troller alone!)
    Click image for larger version  Name:	Node-RED.png Views:	0 Size:	93.1 KB ID:	1483113
    Eman
