Has anyone tested Node Red 2.0 with HomeSeer? I know it was just announced, but looking to see if anyone has tried it yet as a couple of the upgrades appear to be useful.
Node Red 2.0
Guest
Since spud confirmed the release notes didn't suggest anything which would cause a problem, I went ahead and upgraded. My "production" flows are currently working as well as the test dashboard.Karl S
HS4Pro on Windows 10
1070 Devices
56 Z-Wave Nodes
104 Events
Does anyone know if node-red v2 has overcome this issue?.......
Known issues with Node-Red release 1.0.2- Currently, Node-Red is not passing a user/pass to HomeSeer when it issues a request for data. This will result in the inability to get device information (the device list will be empty or some devices will be missing). The solution is to make sure the option "No password required for local subnet" is checked in Setup and do not assign any users to your devices.
Originally posted by Jez View PostDoes anyone know if node-red v2 has overcome this issue?.......
- Likes 1
Originally posted by spud View Post
This wasn't a problem in Node-red itself, but in the HomeSeer contrib. This problem has been fixed since version 1.0.3 of the HomeSeer contrib, so if you install the latest (1.0.6) you can optionally add a user/password when you configure the HS Server in node-red.
