I wan't to first start off with everything I'm trying to do is brand new to me, so I'm wildly ill-equipped to walk down this road correctly.
Main Goal: To pull the Probes Serial Number, Name and Temperature into HS devices
Secondary Goal: To change Target Temperature from HS
Progress: I'm able to get the the raw html data (See screen shots below)
Problem: I don't know how to pull out just the data I need to put into HS.
Flow So far
The Devices Web Page
Raw HTML data (using Flow above) showing Key information needed. The class ser_num only returns the probes serial number.
However the raw data present here always presents the class and serial number associated with the correct Probe Name and Temp.
Flow So far
