Is there an easy way to send the information in Node-RED to two HomeSeer instances.
I'm running two instances of HomeSeer 1) QA/Staging 2)Production. For testing it would be helpful if Node-RED will send the status of the devices two both instances. As both instances are using the same configuration I can imagine that it will work if I can send the info to both servers (IP addresses).
spud Is this something that could be implemented easily?
John
John
