I have some workflow in Node Red but the HS input tells me error while getting status. I tried both configuring HS in node red with and without username and password (I shouldn't need a username as both are on the same computer and HS is configured not requiring a username under that situation).
As web hook I am using http://127.0.0.1:1880/homeseer/webhook
The HS module in Node Red is v1.0.6 which seems the most current one.
Why can it not connect?
