Hi spud, let me try to articulate the issue better.
- Create a virtual device in HS4 v4.1.18.0 or later. That device will show up in the Devices page as two separate sub units with different Ref IDs, a root device and a Control child/feature. Note: previous versions of HS4 only created one device
- Create an Event with an action of Easy Trigger set Device's String To: and try to select the virtual device just created. In the drop down what appears is only the Control child/feature.
- Setup a HS Device node in Node Red and set it to the virtual device in our example.
- In the previously mentioned event, set the device string to something.
- In node red, the device string is not updated/passed in the payload.
- Go back to the virtual device in HS4 and delete the Control child/feature.
- Go back to the Event and reselect the object for the Set Device String function, now the root device shows up.
- Go back to node red and reselect the HS node and set it the same object as we just did on the Event.
- In the event set the device string to something.
- The HS node in Node red now reflects that change.
