Lately I have had issues with my HS devices not updating in NR. I just used the HS device node, that used to update when the state of a switch or door sensor changed. It stopped doing that. So I used a status node instead. That does not update when the status of the window in this example changes. Below the status node is the HS device for this window I used before. I could use a inject node and inject a 'sync' every minute or so, but that would mean I have to change a ton of stuff, and staus node and hs nodes used to work until a week or two ago
I run NR in iobroker on windows 10 pro. I recently reinstalled and updated iobroker to the newest version. HS4 version 4.2.18.0
