How do I make my Echo speak when devices change? - TTS is configured!
    #31
    Originally posted by ksum View Post
    macromark...If instead you wanted to have a HomeSeer device report only specific status changes, well that's easy! You use a Switch node after the HomeSeer node and only have it check msg.payload.staus for the values you want. Then connect those all (night only be one) to the change node after the HomeSeer one.
    Yes, this is exactly what I was looking for. Thank again Karl! 👍
      #32
      Originally posted by Marty_B View Post
      object
      ref: 556
      name: "Alexa Garage Door Open"
      location2: "Virtual Devices"
      value: 100
      status: "On"
      last_change: "/Date(1605472363860-0500)/"
      text: "The is On"
      The text is spoken by Alexa as "The is on"
      ksum This is also what I'm seeing on some devices. "voice_command" is not in the debug log.
        #33
        I think this is because when HS4 sends update to node-red via the webhook, it only sends a few fields (ref, name, value, status, location, location2)
        Anyway, I think it would be better to add the node name in the message so that you can use something like msg.node_name instead of msg.payload.voice_command in your flow. If you agree I will add that in the next version.
          #34
          That would be awesome!
            #35
            I had expected that a Status or Control request, as well as an update coming out from HomeSeer would all contain the same information, spud If this is not the case, I believe it would be good. Having all the device information is nice in some cases.
            Karl S
            HS4Pro on Windows 10
            1070 Devices
            56 Z-Wave Nodes
            104 Events
              #36
              Yeah... this is not the case, I will add a enhancement request so that HS4 send all the device info when sending an update through the webhook.
                #37
                in version 1.0.5 of node-red-contrib-homeseer, any message sent from a HS Device node, now has a nodeName property which is set with the name of the node.
                so, macromark instead of using msg.payload.voice_command or another workaround, you can use msg.nodeName.
                  #38
                  Sweet Add, spud !!! Thank you!!
                  Karl S
                  1070 Devices
                  56 Z-Wave Nodes
                  104 Events
                    #39
                    macromark did I misunderstand your request? I thought you wanted to only announce when the doors from your other examples were opened/closed when there was motion being reported by a sensor. If instead you wanted to have a HomeSeer device report only specific status changes, well that's easy! You use a Switch node after the HomeSeer node and only have it check msg.payload.staus for the values you want. Then connect those all (night only be one) to the change node after the HomeSeer one.
                    Karl - This works really well for a sensor that has "Motion" and "No Event" status strings. However, I have some motion sensors that have "Motion" and "No Motion". So, I would want to filter out the "No Motion" status announcements. How would I do this? There is no "Does Not Contain" function.
                      #40
                      Put 2 items in the Switch node, macromark The first one looks for "No Motion" and the second looks for "Motion" with the setting at the bottom of the node set to "stopping after first match." This will give you two outputs. Connect the second but not the first. I can get images if you need them.
                      Karl S
                      1070 Devices
                      56 Z-Wave Nodes
                      104 Events
                        #41
                        This? Not sure I understand the logic? If the status is "No Motion", the first match would be "Contains Motion"... which is does. Wouldn't it just pass "No Motion" to the Alexa Routine node?
                          #42
                          Close! Grab the 3 line icon on the left of the No Motion one by and drag it up above the other. Just like a drag and drop file move/copy in Windows.
                          Karl S
                          1070 Devices
                          56 Z-Wave Nodes
                          104 Events
                            #43
                            How does that prevent Alexa from speaking "No Motion" while is allows "Motion"? I still don't understand why.
                              #44
                              With "No Motion" being first, and having it stop at the first instance, the flow will go to the first output in the Switch node when there is No Motion. Do not connect that output to anything and the flow stops there. It will look similar ro this in the flow diagram:
                              So if the first condition is met, nothing happens. If the second is met, it continues on down the flow. Make sense?
                              Karl S
                              1070 Devices
                              56 Z-Wave Nodes
                              104 Events
                                #45
                                THAT was the missing bit of data that I needed! OK, so the switch node with X rules has X connectors. Got it. I understand now. Thanks again!
