i need a switch that i can turn on or off so i can control when things are spoken
hs virtual switch ? maybe
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
[{"id":"3c7a0472.72c77c","type":"hs-device","z":"51c074b1.9415ec","name":"Announce Status","device":"416","server":"e002f3ec.8aabe","feature":0,"reportonstartup":true,"x":290,"y":1120,"wires":[["2c831a48.444f26"]]},{"id":"b292e640.d6c078","type":"gate","z":"51c074b1.9415ec","name":"","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"x":830,"y":1160,"wires":[["368b406e.4868d"]]},{"id":"af1947d9.871e18","type":"switch","z":"51c074b1.9415ec","name":"","property":"payload.status","propertyType":"msg","rules":[{"t":"eq","v":"On","vt":"str"},{"t":"eq","v":"Off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":450,"y":1220,"wires":[["6ec95a43.aab344"],["fe857c61.e8ad6"]]},{"id":"6ec95a43.aab344","type":"change","z":"51c074b1.9415ec","name":"Set gate to Open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":1160,"wires":[["b292e640.d6c078"]]},{"id":"fe857c61.e8ad6","type":"change","z":"51c074b1.9415ec","name":"Set gate to Closed","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":1220,"wires":[["b292e640.d6c078"]]},{"id":"2c831a48.444f26","type":"delay","z":"51c074b1.9415ec","name":"","pauseType":"delay","timeout":"15","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":380,"y":1180,"wires":[["af1947d9.871e18"]]},{"id":"e002f3ec.8aabe","type":"hs-server","z":"","name":"House","host":"192.168.1.10","port":"8008"}]
