Alexa remote
    Alexa remote
    Someone took the lead on this one !
    https://flows.nodered.org/node/node-...lexa-cakebaked
    you’ll need to removes your alexa nodes (take a picture or something ) delete the old alexaremote2 node red package. Install your new one. Replace your nodes
    This will allow the new maintainer and the community(pull request) to add the latest features , i.e sending a text command directly from nodered .
    But for now , this should improve stability of connection .
    I had already updated the dependencies on my setup with the old package with npm. It seems to be more stable , but didn’t test more than one day.
      That is a great news. I'm wondering if you can set the routine to home or away. Alexa has a nice routine that if you are away, it check on the sound of the smoke detector, the problem that most likely I will forge to put it in away mode while I could easy do it with this node-red.
      Sent from my SM-G973U1 using Tapatalk
