Alexa-remote2 contrib up-to-date
    There have been changes on amazon side. So old alexa-remote2 contrib stopped functioning.
    It is possible that the old one started to work again.
    Appolon77 just did an in-depth refactor of the cookies handling in his alexa-remote2 library. Everything is up to date.
    Here is a nodered contrib I have put online that has all the dependencies updated :
    https://flows.nodered.org/node/node-...remote2-mattl0
    npm : https://www.npmjs.com/package/node-r...remote2-mattl0
    Github: https://github.com/MattL0/node-red-c...remote2-mattl0
    You can change the old contrib to the new one via npm (fastest) or via Nodered palette (longer but maybe easier for some since it is done via the Node-red ui).
    1. Npm :
    From your nodered node pc folder via ‘’npm remove <old-package-name>‘’ .Then, install the new one via ‘’npm install <new package name>.
    2. Node-red UI :
    1- Export ALL your flows (tabs) into a json via export function of nodered (copy it into notepad).
    2- Delete ALL your Nodered Tabs.
    3- Delete alexaremote config node but take a screenshot before.
    4- Remove old Alexa-remote2 contrib from the palette manager.
    5- Install the new Alexa-remote2 package from palette manager .
    6- Import json to recover your flows (see json from #1).
    7- redo setup to initiate account.
    You can also export import only flows related to alexa-remote2 but it is more error prone.
