Originally posted by ewkearns
View Post
Plugs that show outdoor air quality conditions
Originally posted by prsmith777 View Post
That all looks correct except you have a space in "Ext ensions" should read "Extensions"
ScriptingReferences=System.Web;System.Web.dll;System.Web.Ext ensions;System.Web.Extensions.dll (and it still shows up).
Test (Copy and Past from 4 year old config)
ScriptingReferences=System.Web;System.web.dll
Test 2 (Typed addition to Cut & Paste)
Test 3 (Typed from scratch)
...... and it added the [space] when I hit post...
Additional attempt:
ScriptingReferences=xxxSystem.Web;System.Web.dll ;System.Web.Extensions;System.Web.Extensions.dll
HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Operating System: Microsoft Windows 11 Pro - Desktop
Z-Wave Devices via two Z-Net G3s
Zigbee Devices via RaspBee on RPi 3b+
WiFi Devices via Internal Router.
Enabled Plug-Ins
AK GoogleCalendar 4.0.4.16,AK HomeAssistant 4.0.1.23,AK SmartDevice 4.0.5.1,AK Weather 4.0.5.181,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.1,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.51.303.0,JowiHue 4.1.4.0,LG ThinQ 4.0.26.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.3.0
Great ! I use the virtual devices to announce a morning pollen report. I only announce the flu data if its high or very high. Works well.
I am allergic to pretty much all types of pollen. Now that I have it working the goal is to create events to be able to turn off my air exchanger so I'm not sucking that junk inside and turn on my furnace fan to circulate air in my home through the whole home electronic air cleaner filtration system attached to my furnace.
I'm trying to get this to work but I keep getting this error "Running script /usr/local/HomeSeer/scripts/pollen.vb :Exception has been thrown by the target of an invocation.Invalid JSON string"
I'm using this on a RaspberryPi3b with HS3, I've added the Polen.json file to the /user/local/HomeSeer/html/json folder.
I have also added the three image files to the html/images/Pollen folder.
I have also created 4 devices called Today's Pollen Level, Allergen 1,Allergen 2, Allergen 3.
This is what my script looks like.........
Imports System.Web.Script.Serialization
Sub Main(ByVal Parms As Object)
Dim devID as integer
Dim allergenName as String
Dim allergenType as String
Dim allergenTypeValue as Integer
Dim html as String
Dim pollenRating As String
Dim pollenIndex As Decimal
' Create a WebRequest to the remote site, specifying Referer and UserAgent
Dim getRequest As System.Net.HttpWebRequest = System.Net.HttpWebRequest.Create("https://www.pollen.com/forecast/current/pollen/60634")
getRequest.Referer="https://www.pollen.com/forecast/current/pollen/60634"
getRequest.UserAgent = "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_4) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36"
Dim getResponse As System.Net.HttpWebResponse = getRequest.GetResponse()
If getResponse.StatusCode = System.Net.HttpStatusCode.OK Then
' Parse the contents from the response to a stream object
Dim stream As System.IO.Stream = getResponse.GetResponseStream()
' Create a reader for the stream object
Dim reader As New System.IO.StreamReader(stream)
' Read from the stream object using the reader, put the contents in a string
Dim contents As String = reader.ReadToEnd()
' Save JSON string into a JSON file
My.Computer.FileSystem.WriteAllText(hs.GetAppPath & "\html\json\Pollen.json", contents, False)
' Convert JSON string to object
Dim jsonData As Object = New JavaScriptSerializer().Deserialize(Of Object)(contents)
' Get Pollen Index value
pollenIndex = CDec(jsonData("Location")("periods")("1")("Index"))
hs.SetDeviceValuebyRef (281, pollenIndex, True)
hs.SetDeviceString(281, pollenIndex & " out of 12", True)
hs.SetDeviceLastChange(281, now)
For i As Integer = 0 To 2
If i <= UBound(jsonData("Location")("periods")("1")("Triggers")) Then
allergenName = jsonData("Location")("periods")("1")("Triggers")(Cstr(i))("N ame")
allergenType = jsonData("Location")("periods")("1")("Triggers")(Cstr(i))("P lantType")
allergenTypeValue = 0
Select Case allergenType
Case "Tree"
allergenTypeValue = 1
Case "Grass"
allergenTypeValue = 2
Case "Ragweed"
allergenTypeValue = 3
End Select
If i = 0 Then
devID = 281
Elseif i = 1 Then
devID = 283
Else
devID = 284
End If
html = "<img src=""/images/Pollen/" & allergenType & ".png"" height=""32""> " & allergenName
hs.SetDeviceString(devID, html, True)
hs.SetDeviceLastChange(devID, now)
Else
hs.SetDeviceString(284, "None", True)
hs.SetDeviceLastChange(284, now)
End If
Next
End If
End Sub
This has been working great until I switched homeseer systems to new hardware. That was a few months ago but since it was the winter I didn't pay attention to it. It seems to be working accept the virtual device that shows the Index value, just says none. prsmith777 any thoughts?
Flustar.com has had similar data to import including cough, flu, high fever, and strep that I've been using for a year or so. They just recently added covid levels, which I have successfully incorporated into Homeseer. Covid data is not broken out per zipcode. It's pulled from https://flustar.com/api/map/covid19. You can then pull it per region by searching for your three letter city/region code. I also slightly changed the scripts to include Try Catch logic so when the script fails to pull data it adds an error to the virtual devices.
[ATTACH]n1386651[/ATTACH]
[ATTACH]n1386652[/ATTACH]
