Events are not firing as I would expect. Int is likely that I don't understand some obscure nuance of HS3 (it seems to have a lot of those.) Any suggestions?
My goal is to have the door auto-lock when it is closed, IF it was not manually unlocked. I have a door-closed sensor to help with this. The door closed sensor is truly working 100%.
The following event does not fire as expected:
When the door closes it does not lock. The value of Notification is:
As you can see, it is not equal to "Manual unlock Operation". So it should close.
When I remove the "AND IF" line then the door locks every time it is closed.
So why is the AND IF line in the test failing? Why isn't the door locking when it is closed?
