Gas fireplace control during power outage
    So I have a dilemma. I have two gas fireplaces that I would like to control via HS. It uses an on/off light switch, and after doing some research I'm pretty sure that it simply works by way of the switch enabling a thermocoupler or thermopile that creates enough current to open the gas line when you flip the switch. This works when there is a power failure, which has proven convenient in the past when there was a power failure during winter, and we could use the fireplaces to heat the house.
    And here is my dilemma. If I swap the switch for a controllable switch, I get to control the fireplaces remotely - great for turning it off automatically if it's forgotten about or turning it on remotely when in the tub . But not so good for heating the house during a power failure.
    I'm wondering if anyone has thought about any method of being able to remotely control your fireplace that doesn't become useless during a power outage?
    regards,
    Paul
    Yeah.... "Hey honey turn on the fireplace"....
      lol
        If you wire an electronic switch in parallel with the old switch, then you will still be able to turn it on/off with the old switch when power fails.
        tenholde
          Hmm..... At first I was thinking that would mean I'd need to expand the gang box that the fireplace switch is in. But perhaps I can wire an inline electronic switch in parallel at the fireplace end...
            The switch on the wall doesn't do anything other than close contacts on the fireplace ignition. If you look under the firebox, you will see the wire controlling it. In most cases, it's not even a 14-2 but rather a lighter gauge wire. As tenholde mentioned, wire a switch in parallel and you'll be all set. You'll only need to flip open the access at the bottom of the firebox and flip the new switch. Mine has a wireless remote connected instead of a wall switch which does the same thing.
              I used this on my fireplace. Works great with HomeSeer and still provides manual control. My fireplace switch was somewhat hidden on the side so the extra bulk of this switch didn't matter otherwise it might not pass the WAF. There is also a paddle style version. My only caution is don't try testing this thing without attaching it to the actual switch. I learned the hard way and had to disassemble and reset the gears. Regards,
                We have wired this...
                in parallel with the wall switch. When power is out, or not, the wall switch will turn on the fireplace.
                Looks like this...
                https://www.amazon.com/dp/B00WXLRF2U...e-4b1193112941
                is a newer version.
                Michael
                  Looks like this...
                  is a newer version.
                  Or an Aeotech Nano switch should fit behind the toggle in the existing 1-gang box.
                  -Wade
