(Testing) a virgin Linux HS3 v. 531 on a vm I just created (Ubuntu 19.04)
    Some folks here reports that hs3 has a memory leak. As a starting point I wanted to see how hs3 consume memory in a virgin state. Mono stable is installed ( 5.20.1.19)
    HS3 is configured to start as a service.
    1.First picture is when I start the vm.
    2.Second picture, is a little after. I open all the menus i can think off on the web interface. That makes the memory jumps to 114m. I make that to be sure that all what a user could press on is loaded in memory.
    3.Third one I repeat the same process as #2, 10 minutes after. No real effect.
    4. wait 10-15 minutes , doing nothing. 121m
    5. Wait another 15 mins . Memory still in the same range . 122m.
    Just created 5 virtual device with theses two event.
    So every 5 sec, the devices change from off to on.
    Did NOT disable any logs.
    Will let this run for the night.
    -Memory is still the same. 123m.
    -Ten minutes after. memory is at 128m.
    -Another 10 mins. Memory went back to 120m. I think we have a baseline here.
      Good news MattLO!!
      I have not seen any HS3 memory leaks running Homeseer 3 Pro or Lite V531 on Ubuntu 18.04 64 bit.
      Auto mator
        -here after 12 hours . memory is at 135m.
        -35 min after that . still at 135m
        -another 20 min after still at 135m.
        Will report back tomorrow
          Originally posted by Pete View Post
          Good news MattLO!!
          Mine s leaking. This is why i do this test. Will continue for 5-7 days if i can.
            -after another 24 hours . 147m
            -25 min after that still at 147m
              -24 hours later . 169m
              2h after that . 165m
                -24 hours later . Still at 168m.
                -2 hours later same usage. 166m
                IIt is hard to standardize this test... But i think We can conclude that there is no leak with hs3 running Linux.
                Since we have a baseline with no leak..I will install all the plugin I use, and see if there is a leak .
                Installing plugin cause a memory rise ( If we can call this a leak ) .. so the memory will be higher after all the plugin installation.
                But we'll get a baseline and start from here.
                  If you want to keep a record over time, use vmstat command. For example,
                  vmstat 60
                  runs every 60 seconds.
                    Thanks zwolfpack. Is there any way to monitor a particular process?
                    I think i'll just send the values to mqtt and monitor with node-red ( as I did on my real hs3 server), so I'll get a graph of the memory used by hs3 process.
                      Thinking about it, vmstat isn't such a good fit, as it monitors the entire machine, not just a single process. Instead, you could use top, with options to monitor just one process and in "batch" mode
                      top -b -p 937 -d 300
                      where 937 is the process id you want to monitor and 300 is number of seconds per update.
                      To filter out some extraneous stuff,
                      top -b -p 937 -d 300 | egrep "^top|mono"
                      will only pass lines starting with "top" and containing "mono"; this will show the time and the process info.
                        thanks !
                          as i said . installing all those plugin was going to skyrocket hs3 memory usage.
                          -So 318m.
                          will run the command from Zwolfpack 1-2 hours from now.
                          The problem here is the system is doing almost nothing.
                          If memory is stable again.. I will transfer my install into the vm
                            seems stable to me . 318m
                            will chek again tomorrow<
                            top -b -p 937 -d 300 | egrep "^ PID|mai"
                            PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
                            937 root 20 0 2513100 329160 39932 S 6,2 4,3 76:49.94 (System)_22-mai
                            937 root 20 0 2506940 322516 39932 S 10,1 4,2 77:20.27 (System)_22-mai
                            937 root 20 0 2503880 319268 39932 S 10,1 4,2 77:50.60 (System)_22-mai
                            937 root 20 0 2504892 320216 39932 S 10,1 4,2 78:20.95 (System)_22-mai
                            937 root 20 0 2509004 324836 39932 S 10,1 4,3 78:51.28 (System)_22-mai
                            937 root 20 0 2503884 319668 39932 S 10,1 4,2 79:21.64 (System)_22-mai
                            937 root 20 0 2503864 319120 39932 S 10,1 4,2 79:51.96 (System)_22-mai
                            937 root 20 0 2512076 326468 39932 S 10,3 4,3 80:22.91 (System)_22-mai
                            937 root 20 0 2504904 320180 39932 S 10,2 4,2 80:53.44 (System)_22-mai
                            937 root 20 0 2503864 319312 39932 S 10,1 4,2 81:23.80 (System)_22-mai
                            937 root 20 0 2512040 327128 39932 S 10,1 4,3 81:54.24 (System)_22-mai
                            937 root 20 0 2506924 322060 39932 S 10,1 4,2 82:24.49 (System)_22-mai
                            937 root 20 0 2503852 319140 39932 S 10,1 4,2 82:54.93 (System)_22-mai
                            937 root 20 0 2513068 327944 39932 S 10,2 4,3 83:25.43 (System)_22-mai
                            937 root 20 0 2506924 321756 39932 S 10,2 4,2 83:55.96 (System)_22-mai
                              -24 h later 333m
