Originally posted by socalsharky
View Post
New floor thermostat released - with an API.. Who wants to build the PI then?
Simplextech is no longer active on the board, and not doing any HS development. IIRC Michael McSharry took over most of the Simplextech plugins. I would contact him directly to see if he also received any work-in-progress and if there are any plans to continue development.
https://forums.homeseer.com/member/4...chael-mcsharryMy system is described in my profile.
Originally posted by JLehnert View PostSimplextech is no longer active on the board, and not doing any HS development. IIRC Michael McSharry took over most of the Simplextech plugins. I would contact him directly to see if he also received any work-in-progress and if there are any plans to continue development.
-- Cute... after posting I see my Posts count is reduced to a fraction of what it was before I transferred plugins... real cute.
Originally posted by devanb View PostSince the Nvent nuheat signature thermostat works with IFTTT, do you still need to develop a plugin? I would like to control my floor heating via google assistant. Can homeseer events still work using IFTTT without a custom plugin?
Originally posted by socalsharky View Post
A plugin is much better. It is local control, and you don't have to expose your entire HS3 system to IFTTT.
Originally posted by simplextech View Post
Just because it's a plugin does not make it local control. Most Wifi device plugins are using a cloud based API. The same would be true with NuHeat as they only provide a cloud API for status/control of the thermostat. If all is wanted is to use a voice assistant like Google or Alexa there's no need for a HS plugin or IFTTT as NuHeat can be linked directly with Alexa or Google for status/control through their apps. Problem with that is then HS knows nothing about the thermostat so you can't use it in any events.
That's the whole reason I developed the MyHS Token plugin. For use with 3rd parties... the stability of MyHS in general though is questionable for automation use.
