Lost Node ID and trouble with restore
  • bills.hancock@gmail.com
    TLDR - re-installed HS3 software - PROBLEM SOLVED (so far -- 48 hours no issues)
    Follow up...for anyone having similar issues.
    I had installed HS3 on one computer when I first started with the home automation. I was actually migrating from Control4 (which I would absolutely never recommend to anyone...ever). I wanted to test the HS3 waters, so I started a little test bed lab in my house. The structure of the home was well suited to have one area to play and not impact anyone else (read...the wife ). I played with Leviton, Lutron, Smartthings, Phillips HUE, and then HS3. Smartthings was the closest thing to HS3 (that I had tried), but still did not provide the flexibility that I wanted in home automation. Had I spent more time with smartthings, I guess I could have written my own scripts, but I really didn't have that kind of time to devote to this experiment.
    Along comes HS3...
    First few items to install went flawlessly
    First few events (simple) went flawlessly
    Make the decision to go all out with HS3
    Start adding in multiple light switches (something like 50) - learning how to do all the wiring myself - actually fun (and no animals were hurt during the filming of this movie)
    Build a dedicated HS3 computer (along with PLEX server)
    Migrated HS3 to new computer
    After the migration, nothing seem to work smoothly again. Kept having ZNET issues - which were not ZNET issues, but rather HS3 DB issues (thanks to zwolfpack for that clarification). All the problems I was experiencing were on the ZNET node end. I would wake up in the morning and all the nodes were missing - re-install the nodes and all the ID's were gone along with all the events that I had planned. I must have reinstalled those ZNETs 5 times...re-pairing and renaming. Onlly to lose the information a few days later. Purchased new ZNETs thinking that with fewer nodes I wouldn't have this problem -- no luck.
    I was thinking it was ZNET problem all along, but it was the DB files from the HS3 software - SQL problem (see the logs above). Tried restoring old DB files, but I guess they all were corrupted. Nothing seemed to work.
    In a fit of frustration, uninstalled HS3 and started with a fresh copy of the software. I have now been running for 48 hours and for the first time...I have NO RED ENTRIES in my log!
  • zwolfpack
    Did you restore to the corrupted database? That's not going to work - you need to start fresh. Shut down HomeSeer, remove all the *.hsd files from that ..../Data sub folder and restart. If you already tried this (or if this doesn't work), you'd best contact HS support. That would probably be a good idea regardless.
    What should I do at this point?
    I tried a restore from previous backup file. Nothing is coming through...no nodes. The zwave controller is online though.
    Jul-10 10:15:00 PM Log Info The log database is currently 17.75MB in size.
    Jul-10 10:15:00 PM Log Maintenance 30 records, selected by date/time, were removed from the log database.
    Jul-10 10:14:53 PM Error An Invalid Database state was detected when attempting to retrieve the database version.
    Jul-10 10:14:53 PM Database There were errors generated during the save of the database item. Please consult this log for more details and report any data loss to HomeSeer Technologies.
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Sensor In Use failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1497) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Sensor Temperature failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1496) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Occupancy failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1495) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Current Program failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1494) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Humidity failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1493) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Minimum Fan Runtime failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1492) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Fan Status failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1491) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Fan Mode failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1490) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee HVAC Status failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1489) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee HVAC Mode failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1488) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Target Temperature High failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1487) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Target Temperature Low failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1486) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Ambient Temperature failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1485) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Ecobee Main Floor failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1484) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:53 PM Database ERROR, device Plug-ins Restart Restart Version failed to be updated or added to the database.
    Jul-10 10:14:53 PM Error SQL Exception adding device record (Ref=1483) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-10 10:14:31 PM Z-Wave Starting Z-Wave Polling for Network C7AB0F34...
    Jul-10 10:14:27 PM Z-Wave Starting Z-Wave Polling for Network FAC00972...
    Jul-10 10:14:12 PM Web Server Web Server authorized local login successful from: 192.168.1.4 User: rhancock1972
    Jul-10 10:14:05 PM Z-Wave ************************************************************ *******************
    Jul-10 10:14:05 PM Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1469 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1468 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1465 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1464 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1467 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1466 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1461 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1479 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1478 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1463 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1462 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1475 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1474 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1477 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1476 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1471 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1470 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1473 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1472 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1481 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1480 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1482 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:04 PM Z-Wave Garage: ............................................................ ..........
    Jul-10 10:14:04 PM Z-Wave Garage: .............................. FINISHED ..............................
    Jul-10 10:14:04 PM Z-Wave Garage is the SIS for the network.
    Jul-10 10:14:04 PM Z-Wave Garage There is a SUC/SIS in the network.
    Jul-10 10:14:04 PM Z-Wave Garage Controller is static lib.
    Jul-10 10:14:04 PM Z-Wave Garage Controller chip type is ZW050x.
    Jul-10 10:14:04 PM Z-Wave The interface's security support has been set.
    Jul-10 10:14:04 PM Z-Wave Garage: Found 6 Z-Wave nodes in interface node ID 1 (Garage)
    Jul-10 10:14:04 PM Z-Wave Garage: Z-Wave interface node ID: 1, Home ID: C7AB0F34
    Jul-10 10:14:04 PM Z-Wave Garage: Z-Wave Serial API version: 8
    Jul-10 10:14:04 PM Z-Wave Garage: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
    Jul-10 10:14:04 PM Z-Wave Garage: Controller firmware version: 2.8
    Jul-10 10:14:04 PM Z-Wave Garage: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
    Jul-10 10:14:03 PM TTS Speak ():Welcome to Home-Seer
    Jul-10 10:14:03 PM Speaker Speaker host added, Name: QPLEX-Server Instance: Default IP address: 127.0.0.1
    Jul-10 10:14:01 PM Z-Wave Garage: Getting node information from controller...
    Jul-10 10:14:01 PM Z-Wave Garage: The Z-Wave API Execution Thread was Started or Restarted.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1460 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1409 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1408 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1405 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1404 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1407 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1406 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1419 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1403 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1418 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1415 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1414 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1417 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1416 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1411 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1410 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1429 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1413 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1428 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1412 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1425 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Garage: Z-Wave Ethernet at IP 192.168.1.55, connected to interface ok.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1424 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Garage: The Z-Wave Command Execution Thread was Started or Restarted.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1427 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Garage: ----------------------------------------------------------------------
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1426 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Initializing Z-Wave interface Garage (HomeSeer Z-NET Ethernet) at 192.168.1.55, port 2001
    Jul-10 10:14:01 PM Z-Wave Garage: ============================================================ ==========
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1421 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1420 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1439 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1423 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1438 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1422 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1435 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1434 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1437 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1436 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1431 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1430 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1449 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1433 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1448 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1432 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1445 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1444 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1447 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1446 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1441 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1440 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1459 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1443 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1458 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1442 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1455 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1454 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1457 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1456 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1451 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1450 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1453 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1452 no longer exists - removing corresponding objects from the plug-in data.
    Jul-10 10:14:01 PM Z-Wave Main Floor: ............................................................ ..........
    Jul-10 10:14:01 PM Z-Wave Main Floor: .............................. FINISHED ..............................
    Jul-10 10:14:01 PM Z-Wave Main Floor is the SIS for the network.
    Jul-10 10:14:01 PM Z-Wave Main Floor There is a SUC/SIS in the network.
    Jul-10 10:14:01 PM Z-Wave Main Floor Controller is static lib.
    Jul-10 10:14:01 PM Z-Wave Main Floor Controller chip type is ZW050x.
    Jul-10 10:14:01 PM Z-Wave The interface's security support has been set.
    Jul-10 10:14:01 PM Z-Wave Main Floor: Found 20 Z-Wave nodes in interface node ID 1 (Main Floor)
    Jul-10 10:14:01 PM Z-Wave Main Floor: Z-Wave interface node ID: 1, Home ID: FAC00972
    Jul-10 10:14:01 PM Z-Wave Main Floor: Z-Wave Serial API version: 8
    Jul-10 10:14:01 PM Z-Wave Main Floor: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
    Jul-10 10:14:00 PM Z-Wave Main Floor: Controller firmware version: 2.8
    Jul-10 10:14:00 PM Z-Wave Main Floor: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
    Jul-10 10:13:58 PM Info System connected to MyHS Service successfully with license ID 126808.
    Jul-10 10:13:57 PM Info System connected to MyHS Service, waiting for acknowledge...
    Jul-10 10:13:57 PM Z-Wave Main Floor: Getting node information from controller...
    Jul-10 10:13:57 PM Z-Wave Main Floor: The Z-Wave API Execution Thread was Started or Restarted.
    Jul-10 10:13:57 PM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
    Jul-10 10:13:57 PM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
    Jul-10 10:13:57 PM Startup Start up complete.
    Jul-10 10:13:57 PM Startup Starting HSSentry watchdog.
    Jul-10 10:13:57 PM Startup Starting Event Scheduler...
    Jul-10 10:13:57 PM Startup Running the startup script Startup.vb
    Jul-10 10:13:57 PM Startup Starting Find service...
    Jul-10 10:13:57 PM Startup Updater services starting...
    Jul-10 10:13:57 PM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
    Jul-10 10:13:57 PM Speech Listening for remote speaker connections on port 10401
    Jul-10 10:13:57 PM Startup Initializing Speaker Client Interface
    Jul-10 10:13:57 PM Startup Start automation engine...
    Jul-10 10:13:57 PM Startup HStouch server started, waiting for clients to connect.
    Jul-10 10:13:57 PM HSTouch Server Server started on port 10200
    Jul-10 10:13:57 PM Plug-In Finished initializing plug-in Ecobee
    Jul-10 10:13:57 PM Starting Plug-In Ecobee loaded in 108 milliseconds
    Jul-10 10:13:57 PM Starting Plug-In Plugin Ecobee started successfully in 12 milliseconds
    Jul-10 10:13:57 PM Ecobee INFO Ecobee version 3.0.0.32
    Jul-10 10:13:57 PM Starting Plug-In Initializing plugin Ecobee ...
    Jul-10 10:13:57 PM Z-Wave Main Floor: Z-Wave Ethernet at IP 192.168.1.128, connected to interface ok.
    Jul-10 10:13:57 PM Z-Wave Main Floor: The Z-Wave Command Execution Thread was Started or Restarted.
    Jul-10 10:13:57 PM Z-Wave Main Floor: ----------------------------------------------------------------------
    Jul-10 10:13:57 PM Z-Wave Initializing Z-Wave interface Main Floor (HomeSeer Z-NET Ethernet) at 192.168.1.128, port 2001
    Jul-10 10:13:57 PM Z-Wave Main Floor: ============================================================ ==========
    Jul-10 10:13:57 PM Info Plugin Ecobee has connected. IP:127.0.0.1:49551
    Jul-10 10:13:57 PM Plug-In Finished initializing plug-in Z-Wave
    Jul-10 10:13:57 PM Starting Plug-In Z-Wave loaded in 2136 milliseconds
    Jul-10 10:13:57 PM Z-Wave 465 Simple AV Control Command Class Control Commands have been loaded successfully.
    Jul-10 10:13:57 PM Z-Wave 0 event triggers were loaded from HomeSeer.
    Jul-10 10:13:57 PM Z-Wave 0 event actions were loaded from HomeSeer.
    Jul-10 10:13:57 PM Starting Plug-In Plugin Z-Wave started successfully in 1866 milliseconds
    Jul-10 10:13:56 PM Z-Wave 80 total Z-Wave Data Objects loaded.
    Jul-10 10:13:56 PM Z-Wave Network FAC00972 has 58 device data elements.
    Jul-10 10:13:56 PM Z-Wave Network C7AB0F34 has 22 device data elements.
    Jul-10 10:13:56 PM Z-Wave 2 Networks were restored from the data in the database... Building data connections.
    Jul-10 10:13:56 PM Z-Wave Loading Z-Wave Data Objects...
    Jul-10 10:13:56 PM Z-Wave 2 total Z-Wave Network Objects loaded.
    Jul-10 10:13:56 PM Z-Wave Loading Z-Wave Network Objects...
    Jul-10 10:13:55 PM Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
    Jul-10 10:13:55 PM email Initializing email, found 75 messages
    Jul-10 10:13:55 PM Z-Wave InitIO called, plug-in version 3.0.1.252 is being initialized...
    Jul-10 10:13:55 PM Starting Plug-In Initializing plugin Z-Wave ...
    Jul-10 10:13:55 PM Info Plugin Z-Wave has connected. IP:127.0.0.1:49542
    Jul-10 10:13:55 PM Plug-In Finished initializing plug-in Restart
    Jul-10 10:13:55 PM Starting Plug-In Restart loaded in 230 milliseconds
    Jul-10 10:13:55 PM Starting Plug-In Plugin Restart started successfully in 34 milliseconds
    Jul-10 10:13:55 PM Restart Finish InitIO
    Jul-10 10:13:55 PM Restart Setup pairs
    Jul-10 10:13:55 PM Restart Checking for devices owned by Restart
    Jul-10 10:13:55 PM Restart Register callback
    Jul-10 10:13:55 PM Restart Register pages
    Jul-10 10:13:55 PM Restart Setup webpages
    Jul-10 10:13:55 PM Restart InitIO called, plug-in is being initialized...
    Jul-10 10:13:55 PM Restart Set the debug level
    Jul-10 10:13:55 PM Restart Get the list of plugins
    Jul-10 10:13:55 PM Starting Plug-In Initializing plugin Restart ...
    Jul-10 10:13:55 PM Info Plugin Restart has connected. IP:127.0.0.1:49540
    Jul-10 10:13:55 PM Startup Initializing Plug-Ins
    Jul-10 10:13:55 PM Plug-In Found plug-in: Z-Wave, version: 3.0.1.252
    Jul-10 10:13:54 PM Plug-In Found plug-in: Restart, version: 1.0.0.7
    Jul-10 10:13:54 PM Plug-In Found plug-in: Ecobee, version: 3.0.0.32
    Jul-10 10:13:54 PM Startup Checking for available plug-ins
    Jul-10 10:13:54 PM Info Remote plug-in API interface started on port 10400
    Jul-10 10:13:54 PM Error ASP.Net page: Could not load file or assembly 'HomeSeerUtil, Version=3.0.0.1, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Jul-10 10:13:54 PM email Start checking server for email using Gmail
    Jul-10 10:13:54 PM Startup Creating ASP.NET application host...
    Jul-10 10:13:54 PM Startup Initializing email, will check server for new email
    Jul-10 10:13:53 PM Web Server Web Server started on port 80
    Jul-10 10:13:53 PM Web Server Local IP address (subnet) is: 192.168.1.4 (255.255.255.0)
    Jul-10 10:13:53 PM Startup This version of HomeSeer is registered as a HS3PRO version.
    Jul-10 10:13:53 PM Startup Creating Speaker Client Interface Object...
    Jul-10 10:13:53 PM Startup HomeSeer version is: 3.0.0.500
    Jul-10 10:13:53 PM Error Failed to get version information from configuration database (invalid database), data NOT loaded.
    Jul-10 10:13:53 PM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
    Jul-10 10:13:53 PM Startup Loading configuration file ...
    Jul-10 10:13:53 PM Startup Database SAVE process started.
    Jul-10 10:13:53 PM Startup Local voice recognition class started.
    Jul-10 10:13:53 PM Startup Plug-In Interface class started.
    Jul-10 10:13:53 PM Startup E-Mail RECEIVE class started.
    Jul-10 10:13:53 PM Startup E-Mail SEND class started.
    Jul-10 10:13:53 PM Startup Web server class started.
    Jul-10 10:13:53 PM Startup Application interface class started.
    Jul-10 10:13:53 PM Startup COM port classes started.
    Jul-10 10:13:53 PM Startup Creating Class Objects...
    Jul-10 10:13:53 PM Startup ************************************************************ ********************
    Jul-10 10:13:53 PM Startup HomeSeer version 3.0.0.500 Edition: HS3 Pro Starting Now
    Jul-10 10:13:53 PM Startup Settings Loaded.
  • zwolfpack
    Originally posted by bills.hancock@gmail.com View Post
    I'm not sure if any of the database files are good. Can I delete them and start with a fresh file/database?
    That is an option, sure. You'll may need to exclude & re-add some/all of the Z-Wave devices to get things back in sync.
    Checked my reliability report in win10...no events for a long time. The windows computer is dedicated to homeseer and Plex. No other software... except team viewer.
    Should I use the restore command from the tools and setup tab?
  • zwolfpack
    Hard to say. Check them all.
    Suggest checking Windows Event Viewer for hard disk errors. Need to identify the underlying cause for these corruptions.
    I've never seen anything like this in 3+ years (running on Windows 7).
    I have a back up, but when I restored that one (using the TOOLS --> SETUP) it removed all nodes and my ecobee information.
    Should I be looking at for an older back up?
  • zwolfpack
    The main database, which lives at C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd is corrupted. Check for hard disk errors.
    Z-Wave restore isn't appropriate here, as the Z-Wave controllers aren't what is getting corrupted. All you are doing with restore is writing back what is already there.
    The main database contains, among other things, devices associated with the Z-Wave plugin, one corresponding to each node in the Z-Wave controller. These are what are getting lost when the database gets corrupted.
    Check in the folder C:\Program Files (x86)\HomeSeer HS3\Data\ for backup versions of the database. They will have names like HomeSeerData_1.hsd, etc. One of these may have the previous data.
    Jul-10 9:06:00 AM Energy DB Info All energy database compacting routines completed.
    Jul-10 9:06:00 AM Energy DB Info No Records. Vacuuming database to condense.
    Jul-10 9:06:00 AM Energy DB Info Energy database compaction initiated.
    Jul-10 7:15:00 AM Log Info The log database is currently 17.41MB in size.
    Jul-10 7:15:00 AM Log Maintenance 7 records, selected by date/time, were removed from the log database.
    Jul-10 5:06:00 AM Energy DB Info All energy database compacting routines completed.
    Jul-10 5:06:00 AM Energy DB Info No Records. Vacuuming database to condense.
    Jul-10 5:06:00 AM Energy DB Info Energy database compaction initiated.
    Jul-10 4:15:00 AM Log Info The log database is currently 17.41MB in size.
    Jul-10 4:15:00 AM Log Maintenance 4 records, selected by date/time, were removed from the log database.
    Jul-10 3:14:30 AM Z-Wave Warning A Wake-Up signal was received for node 8, but there is no device found in the system with that Node ID.
    Jul-10 1:28:06 AM Z-Wave Warning A Wake-Up signal was received for node 9, but there is no device found in the system with that Node ID.
    Jul-10 1:15:00 AM Log Info The log database is currently 17.41MB in size.
    Jul-10 1:15:00 AM Log Maintenance 7 records, selected by date/time, were removed from the log database.
    Jul-10 1:06:00 AM Energy DB Info All energy database compacting routines completed.
    Jul-10 1:06:00 AM Energy DB Info No Records. Vacuuming database to condense.
    Jul-10 1:06:00 AM Energy DB Info Energy database compaction initiated.
    Jul-09 10:15:00 PM Log Info The log database is currently 17.41MB in size.
    Jul-09 10:15:00 PM Log Maintenance 7 records, selected by date/time, were removed from the log database.
    Jul-09 9:06:00 PM Energy DB Info All energy database compacting routines completed.
    Jul-09 9:06:00 PM Energy DB Info No Records. Vacuuming database to condense.
    Jul-09 9:06:00 PM Energy DB Info Energy database compaction initiated.
    Jul-09 7:15:00 PM Log Info The log database is currently 17.41MB in size.
    Jul-09 7:15:00 PM Log Maintenance 7 records, selected by date/time, were removed from the log database.
    Jul-09 5:37:42 PM Error An Invalid Database state was detected when attempting to retrieve the database version.
    Jul-09 5:37:42 PM Database There were errors generated during the save of the database item. Please consult this log for more details and report any data loss to HomeSeer Technologies.
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Sensor In Use failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1402) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Sensor Temperature failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1401) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Occupancy failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1400) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Current Program failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1399) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Humidity failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1398) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Minimum Fan Runtime failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1397) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Fan Status failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1396) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Fan Mode failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1395) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee HVAC Status failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1394) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee HVAC Mode failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1393) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Target Temperature High failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1392) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Target Temperature Low failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1391) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Ambient Temperature failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1390) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Ecobee Main Floor failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1389) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:42 PM Database ERROR, device Plug-ins Restart Restart Version failed to be updated or added to the database.
    Jul-09 5:37:42 PM Error SQL Exception adding device record (Ref=1388) to the database: SQL logic error or missing database no such table: Devices, Code=1, Link=
    Jul-09 5:37:24 PM Z-Wave Starting Z-Wave Polling for Network C7AB0F34...
    Jul-09 5:37:18 PM Z-Wave Starting Z-Wave Polling for Network FAC00972...
    Jul-09 5:36:59 PM Z-Wave ************************************************************ *******************
    Jul-09 5:36:59 PM Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1359 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1358 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1355 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1354 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1357 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1356 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1353 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1352 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1379 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:58 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1385 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1384 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1387 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1386 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1381 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1380 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1383 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1382 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1364 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1361 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1360 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1363 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Warning Garage: HomeSeer device with reference ID 1362 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:57 PM Z-Wave Garage: ............................................................ ..........
    Jul-09 5:36:57 PM Z-Wave Garage: .............................. FINISHED ..............................
    Jul-09 5:36:57 PM Z-Wave Garage is the SIS for the network.
    Jul-09 5:36:57 PM Z-Wave Garage There is a SUC/SIS in the network.
    Jul-09 5:36:57 PM Z-Wave Garage Controller is static lib.
    Jul-09 5:36:57 PM Z-Wave Garage Controller chip type is ZW050x.
    Jul-09 5:36:57 PM Z-Wave The interface's security support has been set.
    Jul-09 5:36:57 PM Z-Wave Garage: Found 6 Z-Wave nodes in interface node ID 1 (Garage)
    Jul-09 5:36:57 PM Z-Wave Garage: Z-Wave interface node ID: 1, Home ID: C7AB0F34
    Jul-09 5:36:57 PM Z-Wave Garage: Z-Wave Serial API version: 8
    Jul-09 5:36:57 PM Z-Wave Garage: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
    Jul-09 5:36:57 PM Z-Wave Garage: Controller firmware version: 2.8
    Jul-09 5:36:57 PM Z-Wave Garage: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
    Jul-09 5:36:56 PM TTS Speak ():Welcome to Home-Seer
    Jul-09 5:36:56 PM Speaker Speaker host added, Name: QPLEX-Server Instance: Default IP address: 127.0.0.1
    Jul-09 5:36:54 PM Z-Wave Garage: Getting node information from controller...
    Jul-09 5:36:54 PM Z-Wave Garage: The Z-Wave API Execution Thread was Started or Restarted.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1351 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1350 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1309 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1308 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1305 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1304 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1307 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1306 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1301 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1300 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1303 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1302 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1329 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1328 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1325 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1324 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1327 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1326 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1321 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1320 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Garage: Z-Wave Ethernet at IP 192.168.1.55, connected to interface ok.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1323 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1349 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1322 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Garage: The Z-Wave Command Execution Thread was Started or Restarted.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1348 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Garage: ----------------------------------------------------------------------
    Jul-09 5:36:54 PM Z-Wave Initializing Z-Wave interface Garage (HomeSeer Z-NET Ethernet) at 192.168.1.55, port 2001
    Jul-09 5:36:54 PM Z-Wave Garage: ============================================================ ==========
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1299 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1298 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1345 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1344 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1347 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1295 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1346 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1294 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1341 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1297 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1340 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1296 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1343 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1342 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:54 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1319 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1318 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1315 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1314 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1317 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1316 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1311 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1310 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1313 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1339 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1312 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1338 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1335 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1334 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1337 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1336 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1331 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1330 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1333 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Warning Main Floor: HomeSeer device with reference ID 1332 no longer exists - removing corresponding objects from the plug-in data.
    Jul-09 5:36:53 PM Z-Wave Main Floor: ............................................................ ..........
    Jul-09 5:36:53 PM Z-Wave Main Floor: .............................. FINISHED ..............................
    Jul-09 5:36:53 PM Z-Wave Main Floor is the SIS for the network.
    Jul-09 5:36:53 PM Z-Wave Main Floor There is a SUC/SIS in the network.
    Jul-09 5:36:53 PM Z-Wave Main Floor Controller is static lib.
    Jul-09 5:36:53 PM Z-Wave Main Floor Controller chip type is ZW050x.
    Jul-09 5:36:53 PM Z-Wave The interface's security support has been set.
    Jul-09 5:36:52 PM Info System connected to MyHS Service successfully with license ID 126808.
    Jul-09 5:36:52 PM Z-Wave Main Floor: Found 20 Z-Wave nodes in interface node ID 1 (Main Floor)
    Jul-09 5:36:52 PM Z-Wave Main Floor: Z-Wave interface node ID: 1, Home ID: FAC00972
    Jul-09 5:36:52 PM Z-Wave Main Floor: Z-Wave Serial API version: 8
    Jul-09 5:36:52 PM Z-Wave Main Floor: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
    Jul-09 5:36:52 PM Info System connected to MyHS Service, waiting for acknowledge...
    Jul-09 5:36:52 PM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
    Jul-09 5:36:52 PM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
    Jul-09 5:36:52 PM Startup Start up complete.
    Jul-09 5:36:52 PM Startup Starting the HS3 Sentry EXE
    Jul-09 5:36:52 PM Startup Starting HSSentry watchdog.
    Jul-09 5:36:52 PM Startup Starting Event Scheduler...
    Jul-09 5:36:51 PM Z-Wave Main Floor: Controller firmware version: 2.8
    Jul-09 5:36:51 PM Z-Wave Main Floor: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
    Jul-09 5:36:50 PM Startup Running the startup script Startup.vb
    Jul-09 5:36:50 PM Info Starting speaker client...
    Jul-09 5:36:50 PM Startup Starting Find service...
    Jul-09 5:36:50 PM Startup Updater services starting...
    Jul-09 5:36:49 PM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
    Jul-09 5:36:49 PM Speech Listening for remote speaker connections on port 10401
    Jul-09 5:36:49 PM Startup Initializing Speaker Client Interface
    Jul-09 5:36:49 PM Startup Start automation engine...
    Jul-09 5:36:49 PM Z-Wave Main Floor: Getting node information from controller...
    Jul-09 5:36:49 PM Z-Wave Main Floor: The Z-Wave API Execution Thread was Started or Restarted.
    Jul-09 5:36:49 PM Startup HStouch server started, waiting for clients to connect.
    Jul-09 5:36:49 PM HSTouch Server Server started on port 10200
    Jul-09 5:36:49 PM Plug-In Finished initializing plug-in Ecobee
    Jul-09 5:36:49 PM Starting Plug-In Ecobee loaded in 437 milliseconds
    Jul-09 5:36:49 PM Starting Plug-In Plugin Ecobee started successfully in 38 milliseconds
    Jul-09 5:36:49 PM Ecobee INFO Ecobee version 3.0.0.32
    Jul-09 5:36:48 PM Starting Plug-In Initializing plugin Ecobee ...
    Jul-09 5:36:48 PM Z-Wave Main Floor: Z-Wave Ethernet at IP 192.168.1.128, connected to interface ok.
    Jul-09 5:36:48 PM Z-Wave Main Floor: The Z-Wave Command Execution Thread was Started or Restarted.
    Jul-09 5:36:48 PM Z-Wave Main Floor: ----------------------------------------------------------------------
    Jul-09 5:36:48 PM Z-Wave Initializing Z-Wave interface Main Floor (HomeSeer Z-NET Ethernet) at 192.168.1.128, port 2001
    Jul-09 5:36:48 PM Info Plugin Ecobee has connected. IP:127.0.0.1:49817
    Jul-09 5:36:48 PM Z-Wave Main Floor: ============================================================ ==========
    Jul-09 5:36:48 PM Plug-In Finished initializing plug-in Z-Wave
    Jul-09 5:36:48 PM Starting Plug-In Z-Wave loaded in 3606 milliseconds
    Jul-09 5:36:48 PM Z-Wave 465 Simple AV Control Command Class Control Commands have been loaded successfully.
    Jul-09 5:36:48 PM Z-Wave 0 event triggers were loaded from HomeSeer.
    Jul-09 5:36:48 PM Z-Wave 0 event actions were loaded from HomeSeer.
    Jul-09 5:36:48 PM Starting Plug-In Plugin Z-Wave started successfully in 3213 milliseconds
    Jul-09 5:36:46 PM Z-Wave 80 total Z-Wave Data Objects loaded.
    Jul-09 5:36:46 PM Z-Wave Network FAC00972 has 58 device data elements.
    Jul-09 5:36:46 PM Z-Wave Network C7AB0F34 has 22 device data elements.
    Jul-09 5:36:46 PM Z-Wave 2 Networks were restored from the data in the database... Building data connections.
    Jul-09 5:36:46 PM Z-Wave Loading Z-Wave Data Objects...
    Jul-09 5:36:46 PM Z-Wave 2 total Z-Wave Network Objects loaded.
    Jul-09 5:36:46 PM Z-Wave Loading Z-Wave Network Objects...
    Jul-09 5:36:46 PM Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
    Jul-09 5:36:45 PM Z-Wave InitIO called, plug-in version 3.0.1.252 is being initialized...
    Jul-09 5:36:45 PM Starting Plug-In Initializing plugin Z-Wave ...
    Jul-09 5:36:45 PM email Initializing email, found 75 messages
    Jul-09 5:36:45 PM Info Plugin Z-Wave has connected. IP:127.0.0.1:49809
    Jul-09 5:36:44 PM Plug-In Finished initializing plug-in Restart
    Jul-09 5:36:44 PM Starting Plug-In Restart loaded in 440 milliseconds
    Jul-09 5:36:44 PM Starting Plug-In Plugin Restart started successfully in 79 milliseconds
    Jul-09 5:36:44 PM Restart Finish InitIO
    Jul-09 5:36:44 PM Restart Setup pairs
    Jul-09 5:36:44 PM Restart Checking for devices owned by Restart
    Jul-09 5:36:44 PM Restart Register callback
    Jul-09 5:36:44 PM Restart Register pages
    Jul-09 5:36:44 PM Restart Setup webpages
    Jul-09 5:36:44 PM Restart InitIO called, plug-in is being initialized...
    Jul-09 5:36:44 PM Restart Set the debug level
    Jul-09 5:36:44 PM Restart Get the list of plugins
    Jul-09 5:36:44 PM Starting Plug-In Initializing plugin Restart ...
    Jul-09 5:36:44 PM Info Plugin Restart has connected. IP:127.0.0.1:49804
    Jul-09 5:36:44 PM Startup Initializing Plug-Ins
    Jul-09 5:36:44 PM Plug-In Found plug-in: Z-Wave, version: 3.0.1.252
    Jul-09 5:36:43 PM Plug-In Found plug-in: Restart, version: 1.0.0.7
    Jul-09 5:36:43 PM Plug-In Found plug-in: Ecobee, version: 3.0.0.32
    Jul-09 5:36:43 PM Startup Checking for available plug-ins
    Jul-09 5:36:43 PM Info Remote plug-in API interface started on port 10400
    Jul-09 5:36:43 PM Error ASP.Net page: Could not load file or assembly 'HomeSeerUtil, Version=3.0.0.1, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Jul-09 5:36:42 PM email Start checking server for email using Gmail
    Jul-09 5:36:42 PM Startup Creating ASP.NET application host...
    Jul-09 5:36:42 PM Startup Initializing email, will check server for new email
    Jul-09 5:36:42 PM Web Server Web Server started on port 80
    Jul-09 5:36:42 PM Web Server Local IP address (subnet) is: 192.168.1.4 (255.255.255.0)
    Jul-09 5:36:42 PM Startup This version of HomeSeer is registered as a HS3PRO version.
    Jul-09 5:36:42 PM Startup Creating Speaker Client Interface Object...
    Jul-09 5:36:42 PM Startup HomeSeer version is: 3.0.0.500
    Jul-09 5:36:42 PM Error Failed to get version information from configuration database (invalid database), data NOT loaded.
    Jul-09 5:36:42 PM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
    Jul-09 5:36:42 PM Startup Loading configuration file ...
    Jul-09 5:36:42 PM Startup Database SAVE process started.
    Jul-09 5:36:42 PM Startup Local voice recognition class started.
    Jul-09 5:36:42 PM Startup Plug-In Interface class started.
  • bills.hancock@gmail.com
    Restore has been very unhelpful/successful
    the only thing that seems to work is scan for devices - light or full
    it obviously doesn't get all the child nodes for the battery powered devices.
    Any suggestions????
    Not sure what happened last night, but accessed Homeseer this AM and all the zwave nodes are gone...I am not sure why this keeps happening. I didn't do anything over the night to the system.
    started a topic Lost Node ID and trouble with restore
    Running HS3 Pro on windows 10
    have 2 znets running with mainly Homeseer switches and a few motion sensors
    while using the Restart plug in I sent the restart command. When the system restarted, I lost all my nodes. I had them backed up along with HS backed up. I tried the restore network command and then test node. No nodes were detected. Using a light scan the nodes would repopulate, but all the node IDs are gone. This also wiped out my events.
    anyway to restore my system properly?
