Michael McSharry : can the DS18B20 sustain high temperatures? Seeing 125C as the maximum; what temperature ranges are you measuring?
Smoker Control / Temperature Monitoring
Guest
Obviously if I was measuring temperatures inside the firebox this would not be a good choice. I am not certain what temperatures are experienced inside a smoker, but I had the impression that normally they are not very high. Don't know what peak temperatures may be experienced.
i used to do 1 wire.. wife didnt like its LOOK.. so it had to go... i even crimped the sensors into an rj11 plug and stuck them in an rj11 wall plate but still no WAF...HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Hi everyone I have a question for you, I hope you can help me with advice. My grill's temperature controller definitely broke down. So I think it would be easier to buy a new temperature controller instead of trying to fix the old one. Do you have any ideas for a good one? Not too expensive cause I don't want to spend much on it. Maybe you know one of these? My brother says that he uses DigiQ DX3, though I would rather go with the more simple stuff.
Originally posted by LoidLiu View PostHi everyone I have a question for you, I hope you can help me with advice. My grill's temperature controller definitely broke down. So I think it would be easier to buy a new temperature controller instead of trying to fix the old one. Do you have any ideas for a good one? Not too expensive cause I don't want to spend much on it. Maybe you know one of these? My brother says that he uses DigiQ DX3, though I would rather go with the more simple stuff.
