trying to get setup with
https://helpdesk.homeseer.com/articl...e-driver-setup
I can follow everything up to step 9 where it tells me to
Nortek HUSBZB-1 Zigbee & Z-Wave Plus USB Interface
but I am having an issue following these instructions.https://helpdesk.homeseer.com/articl...e-driver-setup
downloaded the driver software from the link in the instructions and unzipped the content
Click
Silicon Labs CP210x USB to UART Bridge and then
Next. to select the driver.
I and looked through every sub directory in the zip file but I cannot see that file.
It also says in the instructions I should see the COM ports assigned in Device manager when the Zwave and Zigbee interfaces are listed under other devices but mine shows no com ports there just the device names HUBZ Zigbee com port and HUBZ Zwave com port
Am I to stupid to use this instruction set or what? (I Know, I know)
System is windows 10 Pro
