Anybody using the WADWAZ-1 Door sensor with external contacts? I have several of these that I was using on my Vera system. I thought they were the same as the Monoprice 15270 but I don't see a setting or parameter for the external contact like in the 15270? In Vera the external contact worked without any other set up?
WADWAZ-1 External Contact
The device does not support any parameters and there should be nothing specific related to this device in HS, so it should just work with the external contact. I use similar Ecolink sensors and I didn't have to do anything inside of HS to make it work with the external contact. Are there any errors in the log when you operate it?HS 4.2.8.0: 2134 Devices 1252 Events
Nothing in the logs. Logs show magnet trigger but no external trigger? I have tried 3 from my Vera set up and all 3 act the same. Do you know if the is a default setting for these? I would guess not if there are no support parameters? I have a new one at another location but I have gone to get it yet to try? Thanks for the info
