Fibaro double relais wierd issue
    Hello ,
    My wife had last night a very wierd issue with a double relays from Fibaro. This Relais was working fine for the last 1-2 years , but started playing up last night . Not sure if it is a hardware issue.
    The relais is connected to some lights in the barn and the S1 is connected with a spring loaded switch, the parameter for the toggle/spring loaded switch is set accordingly.
    Last night ,my wife switch the light on with the Physical switch , but she was unable to switch the light off with the toggle switch ( on S1). She was able to switch the light off via Zwave-Homeseer.
    Looking at the logs , I see the multilevel is 1 doing something wierd. :
    Click image for larger version  Name:	2020-06-13 17_53_34-security_heubergau@ad - AnyDesk.jpg Views:	0 Size:	80.9 KB ID:	1393456
    Click image for larger version  Name:	2020-06-13 18_00_18-security_heubergau@ad - AnyDesk.jpg Views:	0 Size:	34.8 KB ID:	1393455
    I don't understand why the multilevel suddenly is in the log and switches the light back on?
    Anyone has an idea? ,
    Cor
