Slightly off topic, but... I have a 1 wire Temp / Humiditiy sensor mounted on the North Side of the house, under the roof, in a small plastic box with some holes drilled in for airflow. This is connected to a temp08 and into homeseer. The temperature readings seem pretty accurate, the humidity sensor seems a bit high. I use the local Airport readings as a comparison.
Now that Winter is upon us I've noticed that the Humiditiy readings I'm getting are pretty nearly flat line at 100% with maybe a slight drop mid afternoon. What I'm wonderting is wheter a) the location of the sensor is correct (I did some reading that suggested the north side in of the house was best) b) the housing that I have the sensor mounted in has sufficient airflow (is this important).
Phill
Phill
