Any options for a z-wave led strip that works well with Homeseer? Maybe with a controller?
Z-Wave RGB LED Strip
I don't have experience with this one but happened to see it today
https://www.monoprice.com/product?p_id=36511
I did build my own board using the Arduino plugin and some other components. It was a pretty bit project so unless you are into building your own PCB board some commercial solution like the one from Monoprice is probably good.
Btw, this is for colored LED strip lights but there are independent inputs and outputs for each color. So you probably can control 4 single-color strip lights with this device. Again, I don't have experience with this device but it's worth a try. I might even consider replacing my custom PCB with this device...
