Fibaro FGK-104 Sensor Replacement for Temperature
  • rge
    https://qubino.com/products/flush-1-relay/
    The temperature sensor looks the same.
  • jbfoster
    Originally posted by ldragon99 View Post
    I am using the remote temp sensor option with the Fibaro FGK-104 in my radiant heat system to control different events. I put the remote sensors into thermowells in the piping at different locations. It looks like they are no longer made or at least hard to find. Are there any replacement zwave temp sensors that are similar?
    These are the temp sensor I use with the Fibaro FGK-10X.
    Jim
    https://www.amazon.com/Gikfun-DS18B2...0476899&sr=8-4
  • ldragon99
    So you use bigger ones? The ones on the sensor I have allow me to *** a remote sensor that can fit in a thermowell. Is that not the case with the ones you mentioned?
  • rge
    Originally posted by BobSpen View Post
    Is it a safety concern when you have a conductor(lead wires of the temp sensor) between a high voltage switch(in an electrical box) and the pool water?
    I put the sensor against the outside of the pool (it’s a steel frame with vinyl liner) insulated from air temperature by a block of polystyrene. Sits nicely jammed behind one of the legs.
    Qubino switch is in a sealed waterproof box and RCD protected, so it’s no more dangerous than the filter pump it’s controlling.
  • BobSpen
    Originally posted by rge View Post
    The temperature sensor option on Qubino switches is similar and works well; I use one for sensing pool temperature.
  • ldragon99
    Rge, do you have a link to the ones you use?
  • rge
  • ldragon99
    started a topic Fibaro FGK-104 Sensor Replacement for Temperature
