Anyone use ecolink tilt sensor (tilt-zwave2.5-eco) associate or link to gocontrol z wave garage door opener.
Ecolink tilt sensor
I have a gocontrol garage door opener. I am migrating it from a SmartThings system to my new HomeSeer system. I’m struggling so far. I was able to add the zwave device (but it took resetting the gocontrol). Now it shows up as a Sigma Entry Controller with no features or buttons or anything. I am searching for help/clues.
markc your issue is different from the OP. Try re-scanning. Or exclude and re-include possibly non-secure. Mine works perfectly with all the features including the "tilt-sensor" which is the door position. Note that the battery for that little thing needs to be changed more often come wintertime.
racerfern, I tried many things with no luck. Rescanning, excluding and re-including (with and without security), resetting the gocontrol, etc etc. Nothing worked. Then as a last ditch try, I excluded the gocontrol, reset it 3 times, and then added it with security. It worked. I’m not sure why but as long as it keeps working, I’m good. Thanks for the advice.
Dan-O Yeah, I've heard lots of horror stories. I've had mine for over three years without that issue. I did have it lose communication with the z-net and had to exclude and re-include twice. But both times it came back just fine. Didn't even have to move it from its mounted spot at the garage door.
I assure you, I'm knocking on wood right now.
- Likes 1
